Hi
I would like your opinion as to the pros and cons of these 2 software. Whitch one to buy?
Regards
Stelios
Results 1 to 11 of 11
Well, I was a PowerDVD user until I found it could not play SVCD's and winDVD could. So now I have both loaded and use WinDVD more due to being able to play SVCD's. I don't know why PowerDVD can't ??? Hmmmmmmm.
PowerDVD lets you capture .bmp files from any dvd, will play .vob files off the hard drive, and well, just looks better. Version 4.0 is the latest and greatest.
How can you make screenshots with PowerDVD 4.0 XP ? On my player, the option is greyed, allthough with PowerDVD 3.0 they work.
Screenshots with WinDVD work. Any help is appreciated. -
Dragonsf, just press the C- key to capture a frame with PowerDVD (if you use WinDVD press P-key).
Well, I just use a software dvd player to unlock the drive or preview a svcd image. Both WinDVD3 and PowerDVD4XP play SVCD, multiple audio, menus. Both have a capture option. Non of them play SVCD or CVD subtitles. So I can not see a major difference. -
That's the problem with my PowerDVD: pressing of the C-Key doesn't work, but I can stup the settings for screen-shots.
But anyhow, I can't see any essential difference between both players too.
Both can pass AC3 digital through, both can play Dragon's lair (PowerDVD 3 couldn't).Pictures on both are clear.
But I think WinDVD is a littel better with SVCDs (menus et. al.) than PowerDVD, but I've to install the latest patch.
WinDVD 4 OEM - where to find it?
By mate in forum Software PlayingReplies: 4Last Post: 19th Apr 2010, 07:42 -
DVD5 played by WinDVD and PowerDVD doesnt show "Hide subtitle" op
By rsb in forum Newbie / General discussionsReplies: 1Last Post: 22nd Mar 2009, 08:11 -
can't see anything on powerdvd
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 11:18 -
Cannot play Blu-Ray in PowerDVD or WinDVD - images are multicoloured snow
By AnitaPeterson in forum Software PlayingReplies: 5Last Post: 17th May 2008, 11:51 -
WinDVD 9 vs. PowerDVD 8?
By Vrex in forum Software PlayingReplies: 0Last Post: 7th Apr 2008, 21:54
