Hey guys, I got a new laptop: Asus G60 (gaming laptop) and I have been using ImgBurn on my past desktops / laptops and it has been very good.
But on this new laptop (OS is Win7) it seems to have an issue with Device Buffer only sitting and not exceeding over 59%.
The DVD-Rom / Burner is 8x. I use high quality (1st class media) and only on this laptop Imgburn is showing 59% Device Buffer. I then hooked up my External 1-16x Sony through USB and it gives a wooping 100% rate (perfect).
So I called Asus complaining about this and they said that the software is not compatible with the internal DVD-Burner and that they recommend me using the software that was installed by the factory; which I think it is called CineNow or something like that. The thing I do-not like about this CineNow software is its very basic and does not give me status of the buffer under run ect. Just shows the percentage of the burning competition.
So I would like to know what are your thoughts on what it could be why ImgBurn is showing a low Device Buffer percentage? I also attempt to burn a DVD+R @ 4x and still the same darn thing.
Do you guys think it’s the software?
Closed Thread
One topic is enough. Continue in https://forum.videohelp.com/threads/316217-Help-ImgBurn-Buffer-Device-59.
Imgburn device buffer showing -6506% when burning dvds.
By xoADAMox in forum Newbie / General discussionsReplies: 0Last Post: 24th Jun 2010, 20:32 -
Help: ImgBurn Buffer Device @ 59%
By butt_crack in forum ComputerReplies: 2Last Post: 5th Feb 2010, 17:22 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 17:22 -
Question why this avi needs to buffer before playing
By jimdagys in forum Software PlayingReplies: 1Last Post: 3rd May 2009, 21:40 -
buffer size question
By socalkev in forum Newbie / General discussionsReplies: 0Last Post: 26th Sep 2008, 16:36
