Hi,
I have to create DVD AVCHD playable on PS3.
I do the authoring of my HD content with encore DVD and I obtain a BD.
If the BD is smaller than 8.5 Gb may I convert it in a DVD AVCHD playable on PS3 without transcoding but only modifiing some system files?
PLEASE HELP.
I don't know another way to see my HD movies edited with premiere on a DISC with menus as a DVD or a BD
Try this http://www.effectmatrix.com/hd-video-converter/how-to-burn-blu-ray.htm
vcd4ever. -
Encore CS4 won't allow AVCHD/BD content on DVD5/9 media, only BD25/50.
You can use MultiAVCHD to create the folder structure, but will lose your authored menus (you can make simple ones with it, but can't keep exisiting ones) -
thanks for the answer.
I have found another web page and i have tried the guide and works great!!!
HERE
Now I'have another problem.
I have a Canon AVCHD videocamera and an iMac
To edit this AVCHD files i use Final cut pro that transform .mts in mov with apple pro res 442 and PCM (video and audio) codec.
Once edited the movie I transcode in H264 with encore DVD or DVD architect (when i use windows).
I make the procedure to see the AVCHD DVD on PS3 but the audio and the video are out of synch.
Any suggestions?
My PS3 plays my AVCHD video well.
By jbitakis in forum DVD & Blu-ray PlayersReplies: 6Last Post: 5th Jan 2012, 14:04 -
AVCHD DVD playback on PS3 failed
By joe4yoshimi in forum Video ConversionReplies: 1Last Post: 29th Dec 2010, 22:54 -
PS3 Stops Playback of AVCHD?
By tommy2010 in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Dec 2010, 02:38 -
Can PS3 play 24-bit 96Khz audio on a DVD as AVCHD etc. ???
By FulciLives in forum AudioReplies: 3Last Post: 13th Sep 2009, 07:45 -
Possible to create a hybrid AVCHD disc with DVD-Video on DVD-R for PS3?
By siegeknife in forum DVD RippingReplies: 5Last Post: 24th Oct 2008, 11:22
