Results 1 to 15 of 15
  1. I been having this issue for the last 2 weeks.
    every time I boot my pc .I have to hit F9 then something about installing Recovery2 from Gigabyte cd .then I have to hit any key for windows to load again.if I don't hit F9 .a disk read error occurred and I have to reboot again
    GA-MA78GPM-DS2H
    BIOS
    F6C
    windows 7
    Oct 2005
    666th portal
    your bios lists no ide master hard drive only a slave? how many drives are there? first thing i would do is check/replace the ide cable and power connections.
  3. I have 2 drives
    80GB HD slave
    DVD burner master
    both on the same channel
    the thing is as soon i hit any key when I get this screen every thing works fine
  4. You should not get the "F9" message unless the software was installed. However, if the software WAS installed, pressing F9 would launch the program. Since you get the message, but no software, it was either only partially installed or the install failed in some way. Or the HD has just recently become damaged or defective.
    This software inserts itself into the OS boot process. BAD, bad, bad, avoid any prog that does this like the plague.
    Fixing this may well involve deleting all partitions, re-formatting, and re-installing all software. EXCEPT Xpress recovery.
    This is similar to the old Gateway software whose name escapes me ATM. The various screwups and problems this crap causes is very fresh on my mind, however.
    You do not mention if you installed the software 2 weeks ago, or if the F9 message has always been present. Absolutely no way in hell this occurred spontaneously without one of the above.
    Also, if possible get the optical and hard drives on different channels. Won't solve this problem but the HD will probably run faster. Unless the optical was just added 2 weeks ago?
  5. Test Subject alfresco's Avatar
    Feb 2007
    I used to get that when I forgot and left the Gigabyte MB disc in the DVD drive. If not, it seems to be running something that's linking to the MB/recovery disc. Maybe it's trying to boot from the DVD drive as it's set as master? Check your BIOS settings to make sure your Boot HDD is set as your boot device and set all the first and next boot options to HDD, none to DVD/CD.
  6. Originally Posted by alfresco View Post
    I did.I changed all 3 of them to HD.I have a feeling it's a BIOS issue,and that is up to date
  7. I sent an email(with pix) to Gigabyte .let see how long it's going to take them to respond.
    by the way.I don't even remember installing any software from Gigabyte CD .just the BIOS flasher that's it and I downloaded that online
  8. Member classfour's Avatar
    The Heartland, United States
    The BIOS flasher didn't change your boot order? If the mobo thinks the DVD drive is the boot drive, it may or may not seek out the hard disc next - unless it's listed in the boot order.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  9. Originally Posted by classfour View Post
    BIOS update didn't change anything .plus I remove the dvd drive from the boot order,and that didn't help
  10. Member classfour's Avatar
    You may have to use a live CD. If you can boot into a ubuntu live CD, there's other things going wrong.
  11. Originally Posted by classfour View Post
    I can boot into windows,but I have to hit F9,and any key every time I start the PC .I get the error msg(Pix) only when I don't hit F9 quickly when windows start .
    I using right now with now issues
    Feb 2008
    Twin Peaks
    Disconnect your dvd drive and see if it finds your HDD, esle reset your bios back to it's default setting.
  13. Originally Posted by lowellriggsiam View Post
    Thanx for the help,but it didn't work.
    I'm going to wait for an answer from Gigabyte support .looks like I need to flash the BIOS back to 1.0
    there is nothing in the BIOS about enable/disable xpress recovery2
    Feb 2004
    Pleasant Hill, CA
    As another source of info, check out the Gigabyte forum at Tweaktown:
    http://forums.tweaktown.com/f69/
    I found them to be very knowledgeable & helpful (even if, ultimately, we couldn't find a solution to my particular problem).
    Good luck.
  15. Originally Posted by Jim44 View Post
    Good luck.
    Thanx Jim,
    I will check that out.still no answer from Gigabyte support
