I use Virtualdub to frameserve my AVI-file (converted with VFAPIConv) to CCE.
This works in Windows 98.
It doesn't work in Windows XP:
CCE 2.25 crashes, CCE 2.64 says Invalid AVI file.
Anyone who can help?![]()
Results 1 to 10 of 10
From what I recalled only CCE 2.50 supports VDR (VirtualDub Frameserver) and not CCE 2.62+
But where can one get CCE? I went to the tools page and clicked through to the demo but there is only user guilds available for download. Any suggestions??
Does frameserving work using windows 2000 server. I have found CCE 2.5. Now I can't seen to get frameserving working using VirtuaDub but I can't seem to open the vdr signpost file, I have tried changing the extention to avi but to no avail. I have tried TempEnc and CCE but neither will open the frameserve file. I am just curious if it is because of Windows 2000 Server. Please help.
I've got the very same problem. I'm looking through the entire forum for answers. WIN2K Professional. :(
did you guys remember to install the Handlers for VirtualDub?
AUXSETUP.EXE in Vdub folder. -
After lots of research and experimenting, my conclusion is:
Frameserving using Virtualdub to CCE2.5 or higher does NOT work in Windows XP in most of the cases. A slight number of users are lucky though.
Solution: Use Win98 2edt. for SVCD encoding.
Good luck.
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
ffvdub or ffdshow encoder image processing doesn't work with VirtualDub?
By Milardo in forum EditingReplies: 42Last Post: 21st Jan 2011, 18:09 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 11:51 -
Virtualdub Deshaker filter has ceased to work
By MrPerson in forum EditingReplies: 0Last Post: 29th Apr 2009, 00:04 -
Can't get MP3 och AC3 codecs to work with Virtualdub in Vista
By NiQ in forum Video ConversionReplies: 4Last Post: 2nd Jan 2008, 21:50
