Hi,.
I tried to convert a divx to svcd with a 2pass vbr in tmpg.
I used the vcdhelp bitrate calc. to do the math so i figured that it would be correct.
Now i ended up with 2 files that are 940mb each and too big to put on a cd even when burnt as svcd.
What could have caused this problem? .. i followed the instructions on converting to svcd from vcdhelp.com
Any help would be appreciated., thanks![]()
Stupid tv!, be more funny!
Im having similar problems. Im trying to put a film from divx, 1 cd, to vcd, but it doesnt seem to let u put more than 80 mins on a cd which is wierd. However, i know that if u cut ur film in half and encode each half separately - dont bother using vbr, constant is good enough - then as long as each half is less than 70 mins or so, u file will not only be less than 700mb, but it will also write correctly when u try.
Im still tryin to find out if u can actually put a 1:30 hour film on one cd. Its pretty lame if u cant. Divx is better but DVD players cant read em... :( -
You'd be beter trying one of the Templates in the Tools section of VCDHELP.COM.
SEFYS is a good one offering up to 100 minutes on one CD with little loss in quality. -
If you have .MPG files which SHOULD fit on a CD (i.e. less than 830MB) yet DONT fit on a CD (SVCD image like 900MB+ from Nero or VCDEasy), the problem most likely:
The stream was set to "MPEG-2" vs. "MPEG-2 SVCD"
or
The stream was set to "MPEG-1(automatic)" vs. "MPEG-1 VCD"
(It's a combo box on the last tab of the settings).
The templates are most often correct, but default settings if you don't use the templates can get you in trouble if you forget this setting. Been bit by this one a couple of times.
Of course, if the .MPG file is like over 830MB, then just make sure you used the same audio bit rate as what you told the bitrate calculator you were going to use.
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 11:31 -
Conversion size is driving me crazy!
By artdog in forum DVD RippingReplies: 8Last Post: 27th Apr 2009, 11:33 -
MPEG-2 528x576 to AVI conversion problem.
By madman1987 in forum Video ConversionReplies: 7Last Post: 3rd Feb 2009, 10:53 -
Conversion of MPEG2 files to smaller size
By tonyaldr in forum Video ConversionReplies: 13Last Post: 2nd Aug 2008, 21:43 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
