Results 1 to 13 of 13
  1. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Gigabyte G33M_S2L mobo pic
    Gigabyte G31M_ES2L mobo pic
    USA
    Hard to tell the height of that cap, but from this view it seems to stick up a bit:
    dsfsadfadsfsadf
    testing smilies in text dsfj sdf sdlfkjds flkjsd lfkjds lfksjd flksjd flksdj flkdsj flksdj fldskj flkdsj fldskj fldskj fldks jflkdsj flkds jflkdsj fldks jflsj lsd jfsdlj fdsl jf
    asds
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    How do you do that?
    In the old software you got an IMG tag you could manipulate, now I can't see a way to do that.
    If I use "upload/manage attachments" I can get an image and drag it into the post, like this:
    But it's still added to the end of the post as an "Attached image" that I can't edit, except to delete, which deletes both images (as actually they're the same image).
    Image Attached Images
    Apr 2004
    Miskatonic U
Name:	Creature exBLagoon.jpg
    Use the Image button above the post area to load multiple images in-line, without having them added as attachments
    Read my blog here.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You can add multiple images in one load
Name:	Yellow Submarine.png
    Read my blog here.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Or add them
    at a time
    Troll test
    You can also edit the image attributes once it is loaded to change it's alignment, and how it is scaled in the general view, as well as adding titles and description meta data.
    If you add an image in-line, then remove it by highlighting and deleting it, it becomes an attachment instead
    Last edited by guns1inger; 11th Feb 2010 at 01:33. Reason: How I wish I could type . . . . . . . .
    Read my blog here.
  7. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I had seen that but it only offers "Please enter the URL of your image" in Opera, my usual browser.
    So I tried Firefox and in that I can upload images.
    It's a bug, either in Opera or weird javascript in the site.
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
ID:	339 test test
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    probably worth reporting here to see if Baldrick can do something about it.
    Read my blog here.
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Double post
    Read my blog here.
  11. Video Restorer lordsmurf's Avatar
    Nothing says you're important like using large obnoxious fonts.
  12. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    its even better when it is all in capitals without and punctuation or formatting such as commas or paragraphs but does have exclamation marks !!!!!!!!!!!!!!!!!!!!!!!!!!!
    Last edited by guns1inger; 6th Mar 2010 at 00:52. Reason: Editor removes my ALL CAPS ?
    Read my blog here.
  13. Video Restorer lordsmurf's Avatar
    maybe YOU HAVE TO USE ALL CAPS ONLY AFTER YOU USED A FEW NON-CAP LETTERS AND DONT FORGET NOT TO USE ANY PUNCTUTATION AND MISSPLLL LOTS OF WOWRDS AND THEN MAKE SURE YOU DONT HOLD THE SHIFT KEY DOWN ALL THE WAYY SO YOU GET LOTS OF 1111111111111s AFTER ALL THE !!!!!!!!!!!!!!!!!!!!11
