the unit has hdmi output, 1080,coax cable in/out, tv tuner
works fine so far, but only thing I noticed is when i put my tv to hdmi to accept the input from the dvd recorder the quality of the picture gets a little fuzzy from the dvd recorder. i have my cable from the wall going in/out on the recorder to the tv. so basically it runs thru the recorder. now if i put my tv to "TV" input the cable quality is perfect, but when i swap it to hdmi to enable the recorder it gets fuzzy.
i just have cable, no pvr or hd box or anything, just standard cable.
it works perfect going thru the dvd-recorder right now, but when I turn on my dvd recorder and i change my tv from "TV" to "hdmi input 1" the quality of the cable goes down, gets more fuzzy. even when I record tv shows with the dvd recorder its fuzzy also.
seems like its loosing quality when being converted to an hdmi signal. how is this possible?
i tried 3 different hdmi cables, now I am not sure what to do. I swapped the unit out for another one, still the same problem
anybody know if this is common problem or should I swap out the unit for another one?
Probably because your DVD Recorder is capable of recording only standard definition signals. So, it is receiving HD signals, down converting it to SD, then up converting the signal to 1080p for use by your TV.
If you want HD on your TV at all times, then try using a signal splitter, and feed both the TV and the DVD Recorder.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
my cables just putting out standard signal, not hd. its just standard def cable. nothing special
I just split the cable before it enters my dvd recorder. so i have 1 coax going into my tv and 1 going into recorder.
it for sure made a difference. much better quality now.
What is the best quality/model splitter I should run? any links? ebay?
Thanks -
Since you have cable, any good quality splitter should work. Just mosey down to Radio Shack, Walmart, K-Mart or Target and pick up one of theirs. They are all resistive dividers, so they all are pretty much the same.
As with just about all of this stuff, you'll get a good quality splitter for a reasonable price from Monoprice: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10422&cs_id=1042206&p_id=...seq=1&format=2
Coax cable splitter question
By txmt in forum Newbie / General discussionsReplies: 9Last Post: 17th Sep 2011, 23:06 -
Picture Quality on a HDTV connected to co-ax cable
By grk417 in forum DVB / IPTVReplies: 3Last Post: 1st Feb 2010, 00:23 -
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 13:09 -
Thin or flat coax cable....does it work ok?
By hygieneboy in forum Off topicReplies: 4Last Post: 29th Aug 2009, 22:28 -
Should I invest in a 2ghz coax splitter for a cable modem?
By yoda313 in forum ComputerReplies: 4Last Post: 23rd May 2009, 09:06
