Hi folks,
Friend of mine converted one of his DVDs ... I guess XviD ISO MPEG4 with the Resolution of 624X352 (1.773) at 25fps ... and I can not watch it on my Philips 5982-37.
Q1: Do I have to change the Resolution to something different? If so, to what?
Q2: How would I do it gthe easiest way? AviDemux or VirtualDub?
I know how to use "Fast Decompress" ... but where do I choose different resolution?
Q3: I scanned thru the Philips 5982 PDF Guide and all it tells me is the Max Resolution ... so where do I find what combination of "Resolutions" the dvd player can handle? So, I won't waste you guys time!
THANKS,
G!![]()
Hi Jagabo,
Thanks for the reply. That's what I thought also ... but when I load it up via my Thumbdrive (8GB) ... it attempts to open up but then Nothing ... No Sound or Picture ... per your recommendation ... here is the Tree Version of MediaInfo ...
General
Complete name : F:\1 Family Movie -CD1.avi
Format : AVI
File size : 699 MiB
Duration : 52mn 34s
Overall bit rate : 1 860 Kbps
Writing application : VirtualDubMod 1.5.10.3 | www.virtualdub-fr.org || (build 2550/release)
Writing library : VirtualDubMod build 2550/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 52mn 34s
Bit rate : 1 405 Kbps
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.256
Stream size : 528 MiB (76%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 52mn 34s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 168 MiB (24%)
Alignment : Aligned on interleaves
Interleave, duration : 128 ms (3.20 video frames)
Interleave, preload duration : 128 ms
Hope this will tell you what the problem is.
Q: Can I just run it thru VirtualDub in Fast Recompress format or something? Might clear up whatevefr glitch it might have!!!
Thanks,
G!
It looks like it should play. Yes, I would try a quick remux with VirtualDub. Also, try Mpeg4Modifier and the Unpack option (if it's "packed").
Hi Jagabo & folks,
Just in a case someone else comes across an AVI like this one ...
I tried the Fast Recompress using XviD in VirtualDub and then used the Mpeg4Modifier ... and the darn thing did NOT work.
So, I tried the XviD4PSP (latest version) ... btw I had never used it before and I chose "Xvid HQ Turbo" for the Vidoe and "MP3 CBR 128K" which was the Default for he Audio and I let it do it's conversion. Since the Original AVI's were 2 CDs ... I did both of them and then Combined them using VDub direct stream copy for both Audio & Video ... file size about 1.18GB. Tried it on my Philips 5982 ... played perfectly with the Exception of about half way in the movie I got jittery playback that usually happens with Packed Bitstream ... this happened for about 1 minute or so then is OK.
Today I combined the the two converted portions with AviDemux and will play it back on Philips and post back my result ... may AviDemux does a better job since it asked me to do something with Timing ... so.
Q1: Does anyone know where I can find a User Guide for XviD4PSP that it will tell me the Differences for all the Different Video Conversion Presets? I had to guess at what I want.
Q2: Can I use Xvid4PSP to combine the Converted AVI's at the same time!?!? I am not sure if the Option exists?
Thanks,
G!
philips 5982 divx playback problem
By wkk in forum DVD & Blu-ray PlayersReplies: 35Last Post: 26th Mar 2009, 13:56 -
Question about AVI files and DVD player Philips DVP 5982
By jtrinc in forum Software PlayingReplies: 1Last Post: 24th Nov 2008, 20:23 -
Philips 5982 - Problem with HDMI sound
By Lawbringer in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jun 2008, 13:32 -
Philips 5982 and USB
By chits007 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Dec 2007, 09:43 -
Philips 5982 Reverse Search Problem
By rvman in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Nov 2007, 02:14
