I use Virtualdub to frameserve my AVI-file (converted with VFAPIConv) to CCE.
This works in Windows 98.
It doesn't work in Windows XP:
CCE 2.25 crashes, CCE 2.64 says Invalid AVI file.
Anyone who can help?![]()
Wish I could help you with this one - VirtualDub's frameserver works fine for me under WinXP!
Did you run AUXSETUP.EXE in the VirtualDub directory and install everything needed for frameserving?
I'm in the process of converting my 10 year old Married with Children VHS videotapes to digital format. The process is as follows:
VCR --> DVMC-DA1
Average episode takes 22 minutes, which rounds out to a 5 gig DV file.
VirtualDub --> TMPGEnc
Crop, resize, black border, plus a filter in VirtualDub then I frameserver to TMPGEnc. 22 minutes takes about 2:40 of encoding time on my Tbird 1.2 Ghz machine.
The source material isn't that great, due to the fact it is ten years old AND due to the fact I rewatched each episode a whole lotta times
SVCD seemed the best way to go, because I wanted to capture as much information off of the VHS tape and wanted to display it as best as I could.
Each episode goes on a CDR by itself. They're only 30 cents apiece, which is nothing.
Eventually I hope to finish converting the 120 or so episodes I have on tape
Frameserving to TMpegEnc under XP works for me too.
Frameserving to CCEncoder is the problem. -
I read in some faq that frameserving with Vdub doesn't work with CCE 2.64, and neither does avisynth
However, vdub to cce 2.50 works under winxp for me
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
ffvdub or ffdshow encoder image processing doesn't work with VirtualDub?
By Milardo in forum EditingReplies: 42Last Post: 21st Jan 2011, 18:09 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 11:51 -
Virtualdub Deshaker filter has ceased to work
By MrPerson in forum EditingReplies: 0Last Post: 29th Apr 2009, 00:04 -
Can't get MP3 och AC3 codecs to work with Virtualdub in Vista
By NiQ in forum Video ConversionReplies: 4Last Post: 2nd Jan 2008, 21:50
