Here's my dilemma:
I created a wedding disc for a friend using Nero Vision (it's actually very decent for disc creation). I gave up on Adobe Encore CS4 cause it kept giving me errors that no one online had solutions for (as in others had the same issue).
The problem is that I created the project using the AVCHD option. Now that it's all done, discs are created, etc. I can't convert or re-output in DVD format. I've done this with Encore in the past with another wedding disc I created. Some members of the families just don't have Blu-ray players.
So I'm hoping that I can rip the AVCHD discs that I've already created (menus and all) to a standard DVD that will play in any DVD player. Otherwise I have to rebuild the whole disc under the DVD option.
Does anyone know how I can do this? From what I can tell all the tutorials are about ripping Blu-rays to AVCHD or single files.
Thanks.
You wont find any tool that converts everything(menus and all) to a standard dvd. You have to manually reauthor it.
See if you can start a new project with dvd menus and insert the video from the avchd disc. That may save you from having to rebuild everything.
AVCHD/"Blu-ray" fails to play on Sony X Box. Should it?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 9Last Post: 24th Aug 2010, 19:34 -
Ask for Tip of a tool just like "Blu-ray to DVD II Pro"
By jjulio1 in forum Blu-ray RippingReplies: 0Last Post: 5th Aug 2010, 09:17 -
My DVD backups are "invalid" in Sony Blu ray player
By KeithMckane in forum Authoring (DVD)Replies: 6Last Post: 26th Feb 2010, 16:11 -
Ripping Blu-ray Movie "BULLITT" Audio Problems
By titot4u in forum Blu-ray RippingReplies: 1Last Post: 16th Nov 2009, 11:22 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 09:08
