I have a bunch of DVDs (90+ that I need to convert to mpeg) and when I use VOB2Mpeg3 and I go from DVD to an external 1T drive, media player
misreports the length of the video and says it is 6 seconds long.
As a control the same DVD will report at 02:02:55 when sent to the internal hard-drive.
Most of the DVDs are flex recorded as the 8 mm tapes are around 2h3min.
But the control shows that when I use the same software I get different results whether I go to the internal hard-drive
(2h02m55) or the external HDD USB (6s).
If I could resolve this I would be interested in buying the registration, but must assume that this problem is possibly
indicatative of something up with VOB2Mpeg3.
Windows Vista Pro 64bit, 6 G Ram
What file system is the external drive?
ok. Can you attach the log from each test please?
No it shouldn't have affected that. Have you got the logs of the other tests you cite?
The logs look to come from 2 different PCs (or different OSs on same PC)
The sucessful log reports there to be VTS_01_5.VOB whereas the failed on does not.
The chapters are different:
Extracting chapter: 1...
The last 2 points suggest an issue with the source. Are those 2 logs from the same DVD? Is DVD in a drive or on the hard drive? If the former - what is the media type?
13:34:44 Start position: 0 End position: 19478528
10:46:37 Start position: 0 End position: 19533824
VOB Wrong Length When Imported
By DebiKay in forum DVD RippingReplies: 3Last Post: 29th Apr 2012, 21:39 -
vob file has wrong length?
By Brainbanana in forum Video ConversionReplies: 16Last Post: 1st Mar 2012, 14:52 -
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
Vob File Length seems all wrong
By AlexHaden in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2008, 19:34 -
CCE SP avi video wrong length
By skipadipadoo in forum Video ConversionReplies: 4Last Post: 7th Nov 2007, 11:14
