  1. Hi!
    I had recently started transcoding avi videos and converting them into x264 mkvs using MEGUI.Now i am stuck with a strange problem: the encoded video's frame width. I am able to do the transcoding but when i play the mkv output,the width does not fit to screen and therefore,on the right end of the screen,i can see a small portion of the same frame being repeated.The original avi plays fine but the mkv output has this problem.And,i face this problem only when playing it in Divx player.When i play it in wmp or vlc player,the frame width seems to be perfect.So is this a Divx playback problem for playing mkvs or is it something else?Any suggestions to solve this strange and annoying problem?
    I have attached screenshots for a better understanding of the problem
    the first screenshot is the mkv file with the width problem (as you can see)
    the second file is the avi
    Thanks in advance.
ID:	208Click image for larger version
    It looks like the divx player ignores the display aspect ratio in the mkv. Can you post the details from the mkv? Use MediaInfio, open mkv, view->text and copy and paste.
  3. Also check the MKV file's frame dimensions. Some decoders don't like non-mod16 or non-mod8 frame sizes.
  4. Video
    Format : AVC
    Format profile : High@L2.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Muxing mode : Container profile=Unknown@2.1
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 57mn
    Nominal bit rate : 425 Kbps
    Width : 660 pixels
    Height : 270 pixels
    Display aspect ratio : 16:9
    Original display aspect ratio : 2.40:1
    Frame rate : 23.976 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.099
    Writing library : x264 core 80 r1376M 3feaec2
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=425 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : A_AAC
    Duration : 1h 57mn
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48.0 KHz
    IM VERY SORRY FOR THE LATE REPLY...
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Why re-encode the avi files at all. If you must have an mkv, you could just repack the content and waste time and risk quality loss
    Read my blog here.
  6. Originally Posted by sanosuke View Post
    Width : 660 pixels
    Height : 270 pixels
    There's your problem. Use Mod16 frame sizes like 656x272 instead.
  7. Thanx!
    will try it out.
    thank you all for ur help.
