Hi:
I've come across a repeated problem when downloading certain files that are encoded with xvid/mp3 codecs that are supposedly dvd/divx player standalone compatible. They play all right but...
The problem manifests itself mostly during frames where there is a static picture (be it a cartoon or with live action video) and the camera zooms in or out of that static picture. When that happens the screen becomes a mess (the closest thing that I can come up to describe it is pixelation where the pixels are huge and out of place). It gets bad enough that the subtitles dissapear momentarily and the screen is total garbage this can happen for a few frames or last a few seconds in the worst cases. The phenomenon can also be observed in fully motion shots but to a lesser degree and it manifest most strongly on static things in the screen like subtitles (of course, assuming hard subs).
What I usually do now is that I simply encode the video again (with something like media coder) and the problem goes away.
However I've recently come across a batch of files that I encode with the XVID4PSP software that renders files with this problem.
I'm pretty sure (given the solution) that this is a option of the codec that creates these problems so I'm wondering If anyone has come across this problem and knows which option causes it.
Thanks for any help.
Results 1 to 9 of 9
Different Divx/DVD players have different abilities. This post describes a lowest common denominator that plays on most Divx/DVD players:
https://forum.videohelp.com/threads/295067-Common-DivX-DVD-Players-AVI-Playback-problems! -
Thanks! I'll check it out. Although I've had two completely different dvd/divx players (BHG currently and a Philips one that broke) and both had the same problem.
There are no hardware decoders that can play Xvid's 3 warp point GMC. Some can handle Divx's single warp point GMC. A lot of newer players can handle QPel.
Ok, but you know what? At least as far as I have been able to see, removing both QPel and GMC have no only cause negligible (in most cases that I have seen, null) reduction in quality, in this case the 2-pass encoding of the original file went from about 52 minutes to 22 minutes. So no complains here about the player not being able to handle it.
Anyways the best solution will probably always be just plug in a cheap pc to your tv (which is what I want to do in the future) and bingo you've got a universal file player for your tv. And frankly any 200 dollar computer can handle video playing just fine. -
The WDTV and WDTV Live don't play Xvid's 3 warp point GMC. They are very low power though. About 4 watts in standby, 9 watts playing 1080p.
Playing Video Files on DVD Player with USB
By Seachd12 in forum Video ConversionReplies: 5Last Post: 20th Dec 2010, 10:04 -
playing on US DVD player multiple files....
By theRealness0820 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2008, 13:09 -
playing files on a dvd player
By rigger1972 in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2008, 13:23 -
Playing MP4 Files on a DVD Player
By neumannu47 in forum Newbie / General discussionsReplies: 6Last Post: 10th Feb 2008, 14:27 -
B-frames causing weird pixelation.
By electrodaveultra in forum ffmpegX general discussionReplies: 2Last Post: 13th Aug 2007, 17:42
