I have no clue what that is haha But you know, you've helped me out with what it could be though I still want to get this hard subbed to the video file. Is that what is stopping me from doing so? Like I mentioned above, the .ass file loaded on AvsP Editor with the colors and such though an error popped up.
The only that I did notice is that when I loaded the video and sub file in aegisub, the subs were smaller and more refined compared to me opening both in Media Player Classic where the subs showed up a little bigger. Maybe that's the style sheet issue? Or because two of each colored streams that pop up as errors are renamed. "Red" and "Matsumoto" (character who speaks during the show) which are both red subtitle.
Results 31 to 41 of 41
I'm not sure, I'm just guessing, but I've seen some that have attached sheets that allow fancy fonts, styles etc..
There might be some errors, colors off etc... without it, but if you're happy with the way it looks, just encode it. If not, you have to fix it or find the style sheet (I think)
save the .avs, open that in vdub, and encode
xvid4psp might pause on those errors, but it work fine in vdub - as i said earlier, I already tested it -
Ah, it loaded with the video with those same errors for the colors. This seems so damn troublesome right now. I have like six programs on my pc that I don't even know how to use at all just to do something I thought was simple. So I encode it with vdub? You mean "Save as AVI..." ?
At least one version of XVID4PSP that is around on the nets (I think r65) didn't come with vsfilter.dll. I have had it happen to me. I am 99% certain that is the error nouseforaname is getting from XVID4PSP.
Download vsfilter. Unzip file and then unzip other zip file inside of that one. Move vsfilter.dll to Path\To\XVID4PSP\dlls\AviSynth\plugins directory.
Re-start XVID4PSP and try loading file and .ass subs again. Should work now. -
Okay so I used that one program, vdub and it did connect the files together. It worked.
Something went real bad and now none of my other files will open up subs at all. I uninstalled all the programs I installed, nothing loads on the original video files. No clue what it is either. -
Well, I do too have problem with the *.ssa subtitle, I've downloaded the Jdorama with softsubs, 'n the subs is in ssa, the rest (.avi) except 1 file, I can do the hardsubbing with avidemux, but only this 1 file (.avi), it said can't load the .ssa file bla..bla..), but if I try to loading the file still using its softsub, the WMP can read the subs (in other words I can watch it in softsub way). Is there anything wrong with the avidemux or something, cause if the file or the subs which is has an error, that means I can't watch it with softsub way, doesn' it?
Can please be kindly to help me solving my problem, cause I want to watch it with hardsub way...
Thank U so much for your kindly help before 'n after
Erika
Hardsub ASS and convert MP4 to AVI
By siseo in forum SubtitleReplies: 2Last Post: 4th Aug 2011, 18:57 -
How to Hardsub Videos with ASS/SSA?
By rbin in forum Newbie / General discussionsReplies: 0Last Post: 27th Dec 2010, 22:03 -
Multiple ASS Hardsub scripts
By alienlinux in forum LinuxReplies: 1Last Post: 10th Sep 2010, 05:50 -
OCR software for video files(hardsub)
By user2008 in forum SubtitleReplies: 4Last Post: 10th Jun 2009, 15:07 -
How do you hardsub .ass files into a .mp4 file?
By kevinayP in forum SubtitleReplies: 1Last Post: 26th Jan 2009, 08:27
