I have been looking for days and have had no luck with any of this. I am essentially looking for 3 things:
-A cheap boom poll (fishpoll) with a mic
-A light to add to my GL1
-A shotgun mic to add to my GL1
Please help! The cheapest boom poll I found was $70 and then the mic was $169.
I haven't been able to find a light for my GL1 and the only shotgun mic I found was the Rode VideoMic for $150.
The GL1 lacks XLR connectors whick limits choice unless you use a Beachtek box or a matching transformer like this. Watch out for mics that require 48VDC phantom power only. Many will run on batteries.
http://www.google.com/products/catalog?hl=en&source=hp&q=shure+a96f&rlz=1R2ADRA_enUS34...wAg#ps-sellers
Here is a good overview report on "low cost" shotguns and boom mounts.
http://www.lafcpug.org/reviews/review_shotgun_mic.html
Videoguys.com has some boom kit packages.
http://www.videoguys.com.au/Shop/p/1976/videoguys-entry-level-boom-microphone-kit-2.html
http://www.videoguys.com.au/Shop/c/314/microphone-kits.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You can make your own boom pole, with some of the money you save you can buy a reasonably good microphone shock mount.
http://www.youtube.com/watch?v=83d3qLHaAN4
http://www.youtube.com/watch?v=xr3uqfvQblA
http://www.youtube.com/watch?v=m4_VHohqy6A
http://www.youtube.com/watch?v=wAep225FZMs
Youtube is your friend in DIY stuff. This is an example, not a recommendation.
"Quality is cool, but don't forget... Content is King!"
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 20:11 -
XLR to 3.5mm shotgun mic
By Gerrysw in forum AudioReplies: 10Last Post: 30th Dec 2011, 17:36 -
Shotgun Mic for Canon Vixia HF S20
By amriteshvara in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 18th Jul 2011, 14:37 -
Shotgun mic for Sony DVD-405
By gmcman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th May 2010, 21:30 -
Looking for a cheap shotgun mic
By 872156 in forum AudioReplies: 8Last Post: 13th Jul 2009, 21:25
