  1. Hello,
    I just got a asus motherboard m2n68-am se2. I purchased it as a barebone kit from tigerdirect, and the memory that would have come with it is on back order. The specs for the memory is: ddr2, pc5400, 667 mhz ,1024 mb , dual ,dimm , 240 pins. I am looking to just buy the memory at a local store, but they offer just pc-5300 or pc-6400. So my question is, will the pc 5300 work in place of the pc-5400? everything else on the pc 5300 is the same as the pc5400.
    If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
    Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078
    USA
    That motherboard appears to be able to use up to DDR2 PC8500 (1066Mhz), so you may be slowing it down a bit using DDR2 PC5300. (667Mhz) It's more commonly used in notebooks. OK for just websurfing and word processing, but encoding may be a bit slow, depending on your CPU. But PC5300 should work fine.
  3. it is just going to be a system for my kids, just for online kids games and a few cd rom games. thanks for the help.
  4. Member classfour's Avatar
    The Heartland, United States
    My favorite is www.oempcworld.com I've yet to get a bad stick, and they ship fast and fair. Also, they will trade you for your old memory if you don't want to ebay it.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  5. Couldn't find the exact board on Crucials site. They have m2n68-am and m2n68-se, both of which are speced for PC2-5300,DDR2 PC2-6400,DDR2 PC2-8500.
    http://www.crucial.com/store/listparts.aspx?model=M2N68-AM
