am capturing usually in 352x288 but i tried in 352x576, it captured fine, no frame drops (am using ATI VCR2 due to limited space right now) and i've tried both xing mpeg encoder and TMPGENC to re-size to PAL VCD format or 352x288 to see if the quality was better.
it seemed like the quality WAS better BUT...both progs crashed at 25% of the encoding!
any suggestions on what i can do to avoid this?
and i know people are gonna diss ATI VCR2 but it gives me a decent result for in AVI format and for converting to DIVX.
this was just something i was trying.
is it better to capture at the size you will want at the end, capture smaller and enlarge or what???
"and then the moonlight hits the town to make me...positively animal"
Hi
Gosh I use to use ATI VCR2 a while ago...
Sounds like your AVI's have bad frames (Your dropping frames) when you have got the AVI, run it through "vdub-mp3-freeze.exe" then you can remove bad frames before converting to VCD Mpeg.
You should be able to capture to DivX also ?
Search Grokster for "vdub-mp3-freeze.exe" or mail me.
downsizing a mov on mac
By devdev in forum MacReplies: 1Last Post: 18th Apr 2012, 10:13 -
Sony Vegas Crashes Using FFDShow Encoder
By send2nik in forum Video ConversionReplies: 2Last Post: 30th Aug 2009, 10:12 -
Resolution downsizing
By neroguy in forum Video ConversionReplies: 7Last Post: 17th Jul 2009, 21:58 -
Windows Media Encoder Crashes
By musomn in forum Video ConversionReplies: 3Last Post: 27th May 2009, 19:00 -
The unmitigated ruler of downsizing algorithms?
By The.Yield in forum Video ConversionReplies: 5Last Post: 9th Nov 2007, 18:02
