I am pretty good with converting/encoding but one thing that has always troubled me is when the source has a video delay. I am trying to is re-encode the video detailed below from 1280x720 to 624x352 in a different format, preferably XviD. I am not very good with virtualdub and use easier programs like Super C, Xilisoft and Handbrake for when I do mkv files. If anyone can help me with this it would be greatly appreciated.
MediaInfo Details of the file i am trying to convert
Code:Format : MPEG-TS File size : 2.26 GiB Duration : 54mn 16s Overall bit rate : 5 953 Kbps Maximum Overall bit rate : 18.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 54mn 12s Bit rate : 5 156 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 59.940 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.093 Stream size : 1.95 GiB (87%) Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 54mn 12s Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Video delay : -6ms Stream size : 149 MiB (6%)
does anybody know if any a pervious version that will work with microsoft framework version 3.0 or older??
unfortunately my server that i use for encoding does not support 3.5
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
mkv 2audio/1subtitle to Xvid/mp4
By felix in forum Video ConversionReplies: 2Last Post: 30th Jun 2009, 07:29 -
MKV to Xvid Avi/MP4 help.
By Born4battle in forum Video ConversionReplies: 1Last Post: 9th Feb 2008, 16:25 -
Issues Converting MKV to MP4 (could be due to damaged MKV header??)
By MohQ in forum Video ConversionReplies: 1Last Post: 1st Feb 2008, 04:10 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25
