hi everyone, i wanna convert a subtitle it is extension (.pac) to something that i can put it on subtitle workshop or any other program to burn it. is there any body can help me?
				Results 1 to 12 of 12
	I changed the thread title.
 pac? never heard of it. Try open the .pac with notepad and see if you can read the subtitles and if so copy and paste some here.
	Hi Tiger,
 PAC is a subtitle-format used in the professional subtitling industry. It belongs to Screen Subtitling Systems
 and can only be opened with professional subtitling software. However there is one company offering a free
 piece of software where you will be able to import PAC and export it as readable text. It's called Titlevision
 and here''s the direct link to this freeware: http://www.titlevision.com/eng_download.htm#tool.
 If things don't work out, send me a PM. I can convert it to SRT, Spruce or whatever...
 And hey, supermighty Baldrick: It's a Danish company! Your neighbours!!
	thanks man, i will try it now.
 i am using poliscript and i want to export from it to a dvd directly but the program i have not fully complete and the dvd exporting is not appear. so that's why i need to convert to another extension.
	i can't download it. it is loading and loading without anything, can u help me more?
	Attach the PAC in your post, I'll convert it for you.
 Will SRT do?
	Hi,
 How to convert SRT file to PAC file format ?
 I try to use Subtitles workshop and FAB Subtitles software to convert, but final output become timecode overlap.
 Thanks.
	Hi there Lippy lipstick. I also need to convert a .pac (or .stl) subtitle to .srt and I tried to follow your advice regarding titlevision. I have can only export it to formats like .usf , .rac or .890 ? I have also tried random subtitle converters out there, but without succes. Can you help me convert a file or tell me what software to use out there? THANKS!!!
	Hello, I downloaded your attachments, tried to open them on Poliscript, but they don't open even though they are .PAC
 first of all how did you save them? and why is the file split to this many small ones? are you sure these are subtitles?
 but anyway, if you have a file on Polisc. in Pac, u can save it as ASCI, set the convert out option to the suitable language (EN1252), then you can open the resulting text file on Subtitle editor or similar cheep ones.
	I have the same problem yet visa versa. And I am in terribly hurry. Could someone help me to convert this? I have to deliver a file until morning and my program crashed.....hi everyone, i wanna convert a subtitle it is extension (.pac) to something that i can put it on subtitle workshop or any other program to burn it. is there any body can help me?
	OK, I know this is a REALLY old thread and all and that no one cares anymore... but I just had a look at those "pac" files that were added as an attachment... THEY'RE NOT .pac files, they're .pac_ files and I really don't think they contain subtitles. Judging by the names, at least some of these .pac_ files contain icons or images. What I'm thinking is that either these .pac_ files are a form of image file OR judging by the underscore in their name, they're some kind of proprietary compression format and the "pac" is actually short for "pack". Last edited by ndjamena; 17th Aug 2015 at 07:28.
  Subtitle Workshop - not creating subtitle at current time locationBy botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 04:09
  how to open chinese subtitle in subtitle workshopBy pcb in forum SubtitleReplies: 2Last Post: 28th Nov 2010, 17:03
  Subtitle Workshop 4 crashes when loading subtitle fileBy Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 07:57
  Problem expanding subtitle time with Subtitle WorkshopBy Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 23:16
  How to open two subtitles files at the same time in Subtitle Workshop?By Talayero in forum SubtitleReplies: 2Last Post: 28th May 2007, 10:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
