I always encoded avi files with Xvid compression method.
I got a new computer with windows vista and reinstalled windows XP on my other computer.
Now for some reason when I open VirtualDub or VirtualDubMod Xvid doesnt even show up on the compression selection list. Why is that??
I have the same exact video codecs that Ive always had installed on both computer, only updated to the newest.
Why wont Xvid show up on the compression choice list next to Divx like it used to??
Results 1 to 9 of 9
Maybe you must manually select xvid vfw in the codec pack...or maybe it was removed...or maybe some other video software installed xvid for you.
I downloaded this like you said. http://www.xvid.org/Downloads.43.0.html
and theres nothing but a bunch of junk files to me. I mean, how the hell do you even install thisor use these??? -
It can be bit tricky to find the correct version over at xvid, but go to http://www.xvid.org/Downloads.15.0.html and you will find a link to http://www.koepi.info/xvid.html .
Or use our mirror https://www.videohelp.com/download/Xvid-1.2.2-07062009.exe -
well alright, installing xvid on its own worked for me. thanks!!
I just wish I knew why I had to install it separately for the first time. Usually its always already been there for me.
Problem with VirtualDubMod - what am I doing wrong?
By bahjan in forum EditingReplies: 2Last Post: 28th Sep 2010, 09:11 -
VirtualDubMod Problem??
By 3thman in forum Video ConversionReplies: 14Last Post: 8th Dec 2009, 11:07 -
By raf.lanna in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2008, 09:01 -
Virtualdubmod problem....
By aruwin in forum EditingReplies: 3Last Post: 20th Sep 2007, 07:41 -
By Mitchum22 in forum AudioReplies: 0Last Post: 15th Jun 2007, 11:28
