I am looking for advice with converting DVD to DivX and or Xvid. I have read around but can only find old posts years old and 32 bit options.
I already have ripping programs so I just need a conveting program but if the good prrograms have a ripper built in that is no problems.
I have an Intel Core 2 Extreme Quad core 2.53G with 8G of ram running WIndows 7 64bit.
Any Ideas would be great?
This discussion thread would seem to indicate that fairusewizard worked on 64bit systems. http://forums.malwarebytes.org/index.php?showtopic=36160
Thanks Hatetea58 and Ai Haibara. Have given xvid4psp a try and that seems ok but I cant work out how to tell it to split a file at a certain size ( like encode at a set quality and break the file once each part gets to 700mb etc) maybe someone knows how to do it in this program?
I know you can do it with Virualdub, Virtualdubmod and nandub. Just open it in that program. Open your video file (or drag it onto the window). Click Video, Direct Stream Copy. Then Save As, and there is a Segment ouput file box and the option under it for filesize limitation
Issues getting DVD Shrink to work under Win7-64bit
By Djinn987 in forum DVD RippingReplies: 11Last Post: 30th Oct 2012, 16:44 -
Lame MP3 on Virtualdub 64bit (win7 64bit)
By EdoScario90 in forum AudioReplies: 5Last Post: 2nd Sep 2012, 10:30 -
I can't change AVC codec to ffdshow under win7(64bit)
By skinney6 in forum Newbie / General discussionsReplies: 8Last Post: 11th Jan 2012, 11:08 -
I can't get multiAVCHD to install running win7 64bit
By Onceler2 in forum Authoring (Blu-ray)Replies: 0Last Post: 17th Sep 2011, 20:29 -
Avi Gain and Win7 64bit problem
By Silsur in forum AudioReplies: 2Last Post: 5th Nov 2010, 05:15
