I'm looking for a program that will take an AVI with PCM and convert it to DVD with PCM.
i don't use it but maybe tmpgenc dvd author. most "authoring" programs take already rendered dvd spec mpeg-2 and audio to create dvds. they mostly don't do the encoding from avi to mpeg-2.
Simple enough, just don't convert the audio when you encode the video. Extract (Demux) the audio with something like VirtualDub or AVIDemux and add it back in when you author. You realize you will have the deduct the size of the PCM audio from the available video size when your re-encode the video? It may take a sizable chunk out of your available video size (Bitrate) if you are converting to DVD. Any particular reason you want PCM audio over a much more compact format like AC3?
Of course if your video file is fairly short, less than an hour, PCM may fit in without much, or minimal, video quality loss.
Suggestions for authoring with both Dolby and PCM soundtracks
By StevenHaefner in forum Authoring (DVD)Replies: 13Last Post: 21st Apr 2012, 22:25 -
Where can I get a program that outputs an "I-frame only" MPEG-2 video?
By Videogamer555 in forum Video ConversionReplies: 8Last Post: 1st Sep 2011, 07:23 -
Authoring program for sub/idx ?
By Capum in forum Newbie / General discussionsReplies: 5Last Post: 6th Dec 2010, 16:15 -
Authoring DVD with four subtitle tracks and PCM audio?
By bizzybody in forum Authoring (DVD)Replies: 7Last Post: 28th Feb 2010, 22:17 -
which dvd-authoring program is better?
By siluet in forum Authoring (DVD)Replies: 9Last Post: 8th Oct 2008, 14:25
