Hi, I have an XviD/avi file burnt on a dvd here, plays perfectly on computer but it consistently gets stuck playing at exactly the same point on dvd player. Burnt to another media, same result. Had a look at it on GSpot, everything looks ok. Anybody know what the problem might be...is there any analysis software that might point out failed frames or similar?
Your AVI type file may be corrupted or damaged. Set top players are more sensitive to that than software players. I would try opening it in VirtualDub and see if any errors show up. Check that 'point' where the player 'sticks' and you may see the problem. VD can step through a file one frame at a time with the arrow keys.
What make and model is your DVD player?
What size is the avi?
How far into the movie time wise does it stick and can you jump to a time point beyond the spot where it sticks?There's not much to do but then I can't do much anyway. -
On stepping through frames VirtualDub found two renegade (unintelligable) frames at the "freeze" points. Cut the frames out....plays perfectly! (but the "Scan for errors" on virtdub didn't pick it up). Problem solved and obliged to you all for your help
I suspected you might find something like that.
I'm not sure why the scan doesn't always work with VD for finding bad frames, maybe it only looks for structure errors. Sometimes you can use the 'Scene change' button for finding bad frames. But if you know where the error is, stepping through the frames is usually the best method.
Avi files "Not Support Video" on dvd player?
By aelfheah in forum DVD RippingReplies: 11Last Post: 12th Sep 2011, 13:18 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
DVD player won't play entire "avi" file
By hifiguy in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2010, 02:05 -
.srt Subtitle in "not DVD" File like mp4, mov or avi
By oldMac in forum ffmpegX general discussionReplies: 2Last Post: 8th Apr 2010, 19:12 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40
