Please correct me if I'm wrong, if I'm using "easycap", what I would need is:Ok, but Modern Warfare is PAL-60 and easycap can't handle that (black and white). I've heard there is a option in recording (NTSC_433) but some people don't get that so therefore have to use other programs.
- The actual easycap device
- 3 Y splitters
- 2 double ended AV cables
I need help as I haven't actualy bought anything yet (wanted to make sure first). May someone please explain clearly how I record PAL-60 using "Easycap"??? (btw Im 15, I aint a computer genius, speak simple english...)
WOULD THAT BE ALRIGHT!? --> http://www.amazon.co.uk/EasyCAP-Video-Capture-Device-Audio/dp/B001G1NKXQ
You need this model to record PAL-60:
http://www.amazon.co.uk/ClimaxDigital-EzCAP-Video-capture-source/dp/B001DERJZ6/ref=sr_...5142694&sr=1-1 -
This thread should answer your questions:
https://forum.videohelp.com/threads/270720-Easycap-Video-Grabber-Capture-card-USB-2-0-RCA-and-S-Video
As for splitters and cables you can find them online as well. -
I bought Y splitters that I think are the wrong type, have a look: http://www.amazon.co.uk/Unbranded-plated-splitter-sockets-760-284/dp/B000L980MU/ref=sr...5660466&sr=1-1
Okay, so I bought what you told me (climax capture card), very similar to easycap, but about the Y splitters, I accidently bought 1 male to 2 female, and as what I've seen from videos, easycap needs y splitters that are 3 phono female RCA sockets.
would this do??
http://www.amazon.co.uk/female-Adapter-Splitter-plated-quanity/dp/B0030LR53G/ref=sr_1_...5658198&sr=8-8
Advice needed for an Xbox 360 capture card.
By Bonno in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2010, 17:15 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
Trying to find the best way to record Xbox 360 gameplay
By Zaz in forum Capturing and VCRReplies: 2Last Post: 2nd Dec 2009, 09:12 -
Xbox 360 gameplay?
By ironman03 in forum Media Center PC / MediaCentersReplies: 2Last Post: 6th Jan 2009, 15:25 -
capturing xbox 360 gameplay trouble
By zookeeper525 in forum Capturing and VCRReplies: 3Last Post: 7th Mar 2008, 19:13
