I've moved from Premier 2.0 to CS4
Just to let you know, I'm using PAL so the frame rate is 25.
The image size is the standard 720 x 576
I'm trying to export it to the best quality possible. I've tried exporting it using both Uncompressed AVI and Quicktime 10bit (blackmagic).
Now, after exporting it, the quality doesn't seem to be what I expected. So I tried exporting it on the older version of Premier 2.0. It clearly
showed that the export quality was a lot more crisp and sharper. Am I doing something wrong? Or is there a problem with Media Encoder?
Someone give me the steps or options I should use to get the best quality. I want to continue using CS4 because I find it a waste working
backwards than forwards. I've tried many times with different settings on CS4 and still the quality is not as crisp. HELP please
What is your source format, project format and how are you monitoring the result?
http://www.kiva.org/about -
Compare the Mediainfo for both of your exported files.
What are exporting from 2.0 in? Uncompressed AVI as well ? I've never had any issues with differing exports and i've been moving through the latest Premieres for a good number of years now, but if you do as edDV says and let us know your source format and how you are determining the difference maybe we'll have some ideas.
Premiere Pro Cs4 exporting issues
By gooberguy in forum EditingReplies: 8Last Post: 27th Jan 2011, 21:15 -
First Steps In Premier CS4
By Sundayarak in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2010, 19:09 -
Premiere CS4 lossless exporting
By timwizard in forum EditingReplies: 7Last Post: 16th Feb 2010, 09:49 -
Premier CS4 and letterboxing?
By beavereater in forum EditingReplies: 2Last Post: 28th Dec 2009, 21:42 -
Exporting AVCHD from Premiere Pro CS4
By jodal in forum Video ConversionReplies: 14Last Post: 29th May 2009, 07:12
