I installed vob2mpg but when i tried to run it i get this error:
Version: VOB2MPG
Build: 3.0.0520
Type: System.ArgumentException
Source: System.Drawing
Message: Font 'Arial' does not support style 'Regular'.
InnerException:
StackTrace: at System.Drawing.Font.CreateNativeFont()
at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
at System.Drawing.Font.Initialize(String familyName, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
at System.Drawing.Font..ctor(String familyName, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet)
at VOB2MPG_PRO.frmVOB2MPGPRO.InitializeComponent()
at VOB2MPG_PRO.frmVOB2MPGPRO..ctor(String[] args)
at VOB2MPG_PRO.Program.Main(String[] args)
I would very much appreciate if someone could help me out here. I'm new at this so I apologise if I'm bothering you with something obviously very simple to solve. tnx
Klemen
You have a corrupt font. What OS do you have? I will send you the uncorrupted version.
Here you go. Just copy the contents of the zip to your Windows\Fonts folder. These are the original XP Arial Fonts.
I've copied the files, overwritten the old ones (they were all the same size as the ones I already had. I still get the error:
Version: VOB2MPG
Build: 3.0.0520
InnerException:
tnx for helping me. -
Ok there is one more to try.... it is something that has happened before: https://forum.videohelp.com/threads/217645-Message-Font-Arial-doesn-t-support-style-Reg...ighlight=Arial
problem with VOB2MPG
By Onceler2 in forum Video ConversionReplies: 3Last Post: 16th Sep 2011, 13:12 -
Cannot run VOB2MPG after program crash
By coriakin in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Mar 2011, 02:36 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
Do you need all VOB's in the set to be able to run VOB2MPG?
By ttucker in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 17th Dec 2009, 11:24 -
vob2mpg problem
By branjk in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Oct 2009, 02:14
