I am really frustrated.
Every file has audio, even inside Encore. I can preview them on the little monitor in the project window.
- I created a new timeline
- dragged one *.mpg file to the timeline, appeared nicely with audio.
- dragged another *.mpg file to the timeline, appeared without audio
Some appear with audio, some not.
If I make a new timeline and start with the *.mpg file that had no audio at first, then the situation is reversed. The ones that had audio don't anymore and vice versa.
My conclusion is that the audio in these clips are somewhat different and there can be only one type of audio on one timeline/audiotrack. (The audio in these clips is MPEG audio, layer2. Only differs by bitrate)
Does anyone know why this is like it is?
Thank You.
I assume you mean Adobe Encore? If so I use it and only import the M2V (Video) and AC3 (Audio) files separate and then I create a timeline and drag the video to it and then the audio to it, I never import the complete MPG (Vid & Audio joined) to a timeline.
Just to clear up above, I did not mean the format has to be in M2V and AC3 (you can use other formats) I just mean that I de-multiplex BEFORE I import into Encore.
Encore increasing timeline size
By koberulz in forum Authoring (DVD)Replies: 47Last Post: 9th Nov 2011, 12:19 -
VirtualDub + Crop Filter adds a black border in right corner of video?
By CactusMan in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2010, 09:24 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 07:51 -
Unlink Video and Audio Track Adobe Encore CS4
By LAM_ in forum EditingReplies: 2Last Post: 23rd Oct 2008, 16:51 -
Encore CS3 - deletes part of video from timeline during build?!?
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 11th Nov 2007, 14:53
