Hi, I'm new to this whole scene, I downloaded some exercise videos (.avi), that I'de like to share with some friends. However some are too big to fit on a normal disc, Ive tried using windows movie maker to cut the beginning and ending short, but the saved file has audio and no picture. What program could I use to either A. compress the file (theyr about 850mb need under 700) or B. Edit the clips so I can cut them into two halfs? thanks! Also my version of Nero does not have any editing tools although it claims to![]()
You could use DVDs instead of CDs, and put 4 to a disc. Otherwise you can use AVI Demux to trim the clips down and save them without re-encoding. Or you can re-encode the whole file to make it smaller with AVI Recomp.
Read my blog here.
DVD file too large to burn to disc..how can I make it fit?
By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 09:14 -
Got two .avi files and need to pare them doen to fit on one dvd, help!
By BroCraig in forum ffmpegX general discussionReplies: 8Last Post: 25th Aug 2009, 13:35 -
How to burn .ts files to make a DVD ?
By comag in forum Newbie / General discussionsReplies: 3Last Post: 13th Jul 2007, 14:28 -
How to burn DVD files that don't fit on DVD?
By aqualung2003 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2007, 01:43 -
What authoring programs offer fit to disk using .avi files?
By dang in forum Authoring (DVD)Replies: 2Last Post: 16th May 2007, 22:05
