Hello there,
I've always had no problem playing TS files on my computer, until i installed the new K-lite codec pack yesterday. I'd installed it so that i could process H264 avi files on virtualdub. Now, when i playback TS files on Media Player Classic or VLC, i have distortions (or whatever that's called?) or lines on the image when there're big actions.
I was just wondering if it does have something to do with the new K-lite codec pack i installed, and if there're any changes to the settings i can make to make the TS playback go back to normal?
example of the playback image here -
http://i49.tinypic.com/34hx82r.jpg
http://i50.tinypic.com/30mc07m.jpg
Thanks!
Results 1 to 20 of 20
i've tried different TS files, the same problem happens.
as for the graphic card, i haven't made any changes since installing the codec pack though. but i'm not entirely sure if that has always happened with VLC, because i don't think i've ever used VLC to playback TS before, i've always used MPC for TS files. sorry, should have made that clear before.
thanks! -
It looks sort of like resized interlaced material
What is the source of the .ts (where did you get them) ? -
i got them from a jpop site.
i've never had problems playing these files though. i tried with files i've played perfectly okay in the past, and they still give me this result now. -
I doubt that both MPC and VLC would encounter the same issues (since they use different systems), I suspect the files are like that , or it's a systemwide issue like graphics card.
If you want , upload a small sample (you can cut it with tsmuxer) , and I'll check to see if playback is like that for me. Or you can check at a friends house to see if the files play like that on another computer -
hi,
sure, i'll do a cut now and upload it.
which download site will be fine for you? -
You can upload directly here if <30MB
Or use a 3rd party site like mediafire.com -
oh, i forgot there was an attachment function here.
have it uploading now but it seems to be pretty slow.
will post again once it's up. thanks! -
here's the sample clip as attached.
it's the same clip i took the second screenshot from.
thanks! -
It's not the best quality, but try changing the deinterlacing mode in VLC (e.g change it to "bob") . But I'm not getting the thick wavy lines in your original screenshots which look like resized interlaced material
Commercials often have different patterns and sources than the actual program portion -
You need the directshow configuration (red icon, not yellow icon like you have in the screenshot) , then checkmark the box on the left hand side that says deinterlacing to enable it. You can fiddle with the different settings, yadif does a decent job. MPEG2 has do be enabled in the decoder configuration as well (under the "codecs" heading in the left hand side)
now the playback works fine with the deinterlacing and MPEG2 enabled, but i'm experiencing laggish playback with the MPEG2 enabled. is there anything else i have to change?
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 10:36 -
correct picture distortions
By ccc in forum Newbie / General discussionsReplies: 3Last Post: 7th May 2010, 23:06 -
WAV audio distortions when editing
By solstrike in forum AudioReplies: 2Last Post: 11th Oct 2008, 00:53 -
Music sound playback is greater than word sound playback
By shknoll in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 14:09 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19
