Hey,
I converted a dvd to vcd using this tools; smart ripper, dvd2avi, tmpgenc en nero...
Is there somehow I can add subtitles using this tools?
Thanks..
No. You need a subtitle filter when you frameserve with VirtualDub or Avisynth or you have to mux subtitle streams to the MPEG (SVCD only).
ToDo list:
1. Read the FAQ and How to.. section
2. Search the forum
3. Repeat 1
4. Repeat 2
5-10. Test
11. If you still have problems you are welcom to ask again.
Not only for SVCD
! You can make it with VCD to.....
Just take a look at this : http://www.vcdhelp.com/subsvirtual.htm
And you see that it's possible to make subtitles with VCD :P
I already make my movies and look fine on my DVD player!
- 8) Glock 8) - -
Selectable subtitles are muxed to the mpeg stream, that is only possible with SVCD. Sorry, I did not explained it correct....mux subtitle streams to the MPEG (SVCD only).
VCD plays only hard encoded subtitles. My favorite subtitle filter is vobsub, that you can use with VirtualDub and Avisynth. -
Hi anGGa,
I have the same problem. Maybe you have a solution at this moment. Please contact me!
Herman Hanssen
h.hanssen@zonnet.nl
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 00:48 -
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 03:09 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 14:17
