Just tell me if I need to do this as joepic says...
or if i am close doing it this way....
1. ! use Powerdvd 7.3 Ultra and also installed blueray hddvd patch.
2. And i make a ISO with the two folders ADV_OBJ and HVDVD_TS with Imgburn.
3. Settings in Imgburn is udf2.5
4.Mount the iso with daemontool.
5.But Powerdvd won´t play the iso, It starts to say "filemode" then nothing happends.
6.Please help !
Computer
win XP sp3
Intel core 2 duo 2,8Ghz
2GB RAM
NVIDIA GeForce 9500 GT
Results 1 to 10 of 10
I'm not sure if powerdvd 7.3 supports mounted iso...maybe you need 7.2.
Or try mount with virtual clonedrive.
Or try play with Arcsoft TotalMedia Theatre. -
If possible, test the problem by making a smaller sample video and burning the HDDVD structure onto a DVD, then try playing the actual disk.
HDDVD is a royal PITA, very few softwares support playback, they may very well be picky about playing a mounted image. -
Sorry about crossing post, I am desperate..
My version of powerDVD supports mounted ISO's, I have tried it with a dvd iso..
I will test this with virtual clonedrive..
jman98
Why i do this that is giving me so much trouble, well je i don't know.... Maybe cause I got a copy of this..
http://www.videoessentials.com/products_main.php
And would really want to use that to tune in my projector.
Otherwise I don't deal with HDDVD, maybe u got a blueray copy of that, u can send me ? -
Baldrick You are the Man !
Virtual clonedrive fixed my problem. To hell with daemontool..
Now I can go on and tune in my room.
Tack !
Powerdvd 9 play BD from Hard Disk
By giosa in forum Software PlayingReplies: 14Last Post: 7th Nov 2009, 12:42 -
Powerdvd won't play movie with an empty BDJO subfolder in the BDMV folder
By gll99 in forum Software PlayingReplies: 0Last Post: 29th Oct 2009, 21:29 -
Mouse won't work in PowerDVD 8 Ultra
By wulf109 in forum Software PlayingReplies: 2Last Post: 3rd Jan 2009, 13:57 -
New PowerDVD 3730 won't read rip HDDVD movie
By kalyway in forum DVD RippingReplies: 5Last Post: 11th Feb 2008, 19:00 -
PowerDVD XP 4.0 Won't Play in Updated WinXP
By SLK001 in forum Software PlayingReplies: 4Last Post: 14th Aug 2007, 11:05
