I am attempting to edit some avi files in V-dub for upload to You Tube. After opening the file, I am trimming the start/stop ends of the clip and trying to save as a new avi with h.264 mp4 video compression, and mp3 audio compression. The problem is that I have no options for mp3 compression under the audio drop down box. As far as I know, I have all the codecs loaded that I need including Fraunhofer IIS.
check out my videos:
http://www.youtube.com/user/DirtBikeMikeHubbard -
thank you for the quick reply. I am now processing the first file. Is it possible to join several avi's together with h.264 commpression into one single file for you tube upload?
AC3 to MP3 in AVI via Virtual Dub
By Simmons in forum AudioReplies: 7Last Post: 22nd May 2012, 19:16 -
WMV9 (AP)/MP3 - Cut without re-encoding. Latest options?
By Golem in forum EditingReplies: 2Last Post: 6th Dec 2011, 19:52 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 20:00 -
Tenders V-Dub MP3 Freeze VBR Audio and Bad Frames Guide
By tenders in forum User guidesReplies: 79Last Post: 15th Sep 2008, 22:34
