  1. I have a DVD that has my son's hockey game on it - with sound. It was recorded with a regular video camera, but there was a "game commentator" using a microphone. The copy I have is fine, but has no intro screen or anything, so I was hoping to "make it a little nicer" to keep as a souvenir ...
    DVD has 2 folders :
    VIDEO_TS: contains VOB, IFO and BUP files
    VIDEO_RM: contains DAT, IFO and BUP files
    I have no idea how to take this and make a new DVD with a nice intro screen. Is it possible? I am not completely computer illiterate, but certainly am somewhat limited in my ability.
    Thanks for any help!
    Use Mpeg video wizard dvd or tmpgenc dvd authoring works to reauthor the dvd with a intro, menu, etc.
    Of you want to use free tools you can try vob2mpg on the dvd and then import the mpg in free authoring applications as dvdstyler or gui for dvd author(or if just one vob import it directly).
    And I changed you thread title so it better describes your problem. You can edit it by click on the edit button.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    PGCEdit's "Import First-Play (startup) clip" may do what you need.
    If in doubt, Google it.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Jim is "The Man" when it comes to this.
    Create a tiny DVD of your intro....just like you were making a regular DVD....then follow Jim's advise.
    I even have a recent thread on this subject as well.....not sure how long ago it was though.
  5. Any chance you can expand a bit more? I hate to play the girlie card, but I think I have to!
    I downloaded the program Jim recommended, but the links to the guide are no longer enabled, so I can't get any info on how to work the program!!
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    OK ... here goes !
    Convert your intro clip to MPEG-1 or MPEG-2 and author it as if it were an entire DVD (so that you have it in IFO/VOB format).
    Open PGCEdit.
    Go to File > Open DVD, and select your VIDEO_TS folder:
    Click Close.
    Go to Title > Import First-Play (startup) Clip:
    Select "don't pause: it's an animated clip":
    Select the VTS_01_0.IFO of your first-play clip:
    Click "Copy VOBs":
    Title 2 is now listed as "Startup clip":
    Go to File > Save DVD:
    You should get the following:
    Now you should be able to burn the VIDEO_TS folder in your favorite burning software.
    If it is a dual layer, I recommend the following (probably OK to use for single layer too!) :
    Go to File > Burn DVD / Create ISO:
    Tick "Burn ISO Image using IMGBurn":
    Choose the relevant options and click "OK".
  7. Wow. Thanks SO much! So glad I found this website ... thank you, thank you!!
