im running windows2000 w/ the 2ed service pack for an OS. i have a all-in-wonder 128 video card and a SoundBlaster Live! Gamer (4.1 sound), and for some reason they conflict w/ each other. i cant have them both working at the same time.
-i have to either have the SoundBlaster disabled to use tv-in on my aiw card or just not fool w/ tv-in and just listen to sound w/ the SBaster....
-if i have sound enabled and try to use tv-in (watch tv on my pc) everything locks up and it maxes out the cpu.
-if you are running the tv-tuner and watching tv on the pc and then enable the sound, it really doesnt enable it, till you restart and by that time the tv tuner wont work.
any1 have a solution? or run in2 this problem in the past?
actually, many ppl have had problems with ati capture cards and soundblaster live, especially on a mother board with a via chipset...if your board has a via chipset you might want to get the via latency patch from viahardware.com it fixed my problem
here my motherboard:
http://www.gigabyte.com.tw/products/7dxr+.htm
^i have an AMD 1.1 or 1.4 GHz in it (cant remember)
-so wait what are you saying to do? get something for the bio's?
thanks a ton man - ive been driving myself nuts over this for 2days now :) thanks
WDTV Live to Soundblaster Audigy 2?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 3Last Post: 12th Dec 2010, 00:25 -
Creative SB Soundblaster Live and Ubuntu 8.04
By Ogilvy in forum LinuxReplies: 6Last Post: 12th Jul 2010, 08:50 -
Audigy Soundblaster SE Installation Problems!!!
By lapetite_66 in forum AudioReplies: 1Last Post: 2nd May 2009, 22:45 -
No soundblaster midi with x-fi extreme audio pci-e
By johns0 in forum ComputerReplies: 0Last Post: 11th Jan 2008, 21:01
