Just wondering because I put my recently burned copy of Top Gear season 14 Bolivia special into an older DVD player and it would play but it was very jerky, almost like there was too much data on the disk for the machine to read properly.
	You must have misstated what you did because no ordinary DVD player will play any Hi-Def material at all. What did you do to it? Did you convert it to a regular DVD? If so, the stuttering could be due to using inferior media, a faulty burn, lousy conversion to DVD, an older player not playing burned DVDs smoothly, lots of things. Can you try it in a different player to test?
 How about starting over and explaining in greater detail what you did - the real source and its resolution (use MediaInfo on it if you don't know), the conversion programs used, the type of media, the burning program used, etc.
	Okay, I'm new to this sorry
 What kind of info should I be looking for? I downloaded the software you suggested.
	Well I think it’s hi-def stuff, the site I downloaded it from says it’s a 720p HD MKV rip, and that is verbatim.
 I converted it from MKV to DVD format to a regular DVD +R.
 I tried it in the exact same method twice, with the same result both times. In my DVD player it says “incompatible disk” and nothing shows on the screen at all, and in the PS2 of my friend the DVD menu does show up, and it will play but it is just very jerky and lags.
 I used VSO ConvertXtoDVD 4, but it’s a trial version and I’m only testing it for now. Could that be the reason? It leaves a watermark in the video.
 The original file is a 720p HD MKV rip of a Top Gear episode (filmed in the UK).
 I used a DVD –R to burn the converted file onto.
 This is the info from the MediaInfo:
 Complete name : C:\Documents and Settings\esdra\My Documents\My Videos\Topgear\Season 14\Top Gear Season 14 Bolivia Special.mkv
 Format : Matroska
 File size : 2.18 GiB
 Duration : 1h 16mn
 Overall bit rate : 4 099 Kbps
 Encoded date : UTC 2009-12-27 21:05:31
 Writing application : mkvmerge v2.9.5 ('Tu es le seul') built on Jun 17 2009 16:28:30
 Writing library : libebml v0.7.8 + libmatroska v0.8.1
 Format : AVC
 Format profile : High@L3.1
 Format settings, CABAC : Yes
 Format settings, ReFrames : 4 frames
 Muxing mode : Container profile=Unknown@3.1
 Codec ID : V_MPEG4/ISO/AVC
 Duration : 1h 16mn
 Bit rate : 3 826 Kbps
 Nominal bit rate : 3 906 Kbps
 Width : 1 280 pixels
 Height : 720 pixels
 Display aspect ratio : 16:9
 Frame rate : 25.000 fps
 Resolution : 8 bits
 Colorimetry : 4:2:0
 Scan type : Progressive
 Bits/(Pixel*Frame) : 0.166
 Stream size : 2.04 GiB (93%)
 Writing library : x264 core 80 r1373M 4322f63
 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / wpredp=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / mbtree=0 / bitrate=3906 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
 Format : AC-3
 Format/Info : Audio Coding 3
 Codec ID : A_AC3
 Duration : 1h 16mn
 Bit rate mode : Constant
 Bit rate : 192 Kbps
 Channel(s) : 2 channels
 Channel positions : L R
 Sampling rate : 48.0 KHz
 Stream size : 105 MiB (5%)
 Language : English
	OK, now we're getting somewhere. It's not an HD-DVD. It's just a regular old DVD that happens to have been made using an HD source. Does it play OK on the computer, the DVD video? Did you test? Play it using PowerDVD or something like that. Then, when you put your burned DVD disc back into the DVD-ROM, does it play OK from there? It's only in your standalone unit that it stutters? Can you test it on a different standalone, perhaps at a friend's house?
 If it's jerky when doing the 2 computer tests, the conversion screwed up. If it's good on the computer but jerky on your player, it's probably either a media problem or a burning-to-disc problem. If it's also jerky on a friend's newer player, it's definitely a media or burning problem. If it's only jerky on your player, it's probably that your old player doesn't play burned DVDs properly. You might try burning to DVD-R to see if it plays any better. Otherwise, get a new player.
 What kind of media is it? And burning problems can often be solved by burning using ImgBurn. If you used Nero or something else, try doing a test burn with ImgBurn.
	Not sure where you live, but if you're in NTSC land you might have ended up with a PAL DVD (the original file was 25fps), which might explain the "incompatible disk" message on you player.
  Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic PlayerBy Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55
  DVD will play on new DVD player, but won't play on oldBy joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 19:57
  Can a dvd player that able to play dvd+r dl play dvd-r dl or does this varyBy dymx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2007, 15:33
  Can a dvd player that able to play dvd+r dl play dvd-r dl or does this varyBy dymx in forum DVD RippingReplies: 1Last Post: 22nd Oct 2007, 12:30
  What is an "older" DVD player?By lordsmurf in forum DVD & Blu-ray PlayersReplies: 8Last Post: 13th Jun 2007, 18:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
