Results 1 to 17 of 17
    Mar 2006
    Australia
    Does anyone know how to extract the 7 discrete wavs from a DTS-ES track?
    Thanks.
    Feb 2010
    Switzerland
    Hello,
    This is a great Tool for Audio Transcoding:
    http://forum.doom9.org/showthread.php?t=125966
    eac3to, command Line Tool
    Gui:
    http://www.digital-digest.com/software/EAC3toGUI.html
    Your Source File: .dts or .cpt
    Destination File:
    for 6 Channel wave File .wav or monofiles .wavs
    Mar 2006
    Australia
    Originally Posted by Malcom X View Post
    ... This is a great Tool for Audio Transcoding:
    eac3to ...
    Thanks, but I have already tried that; eAC3to does not handle my DTS-ES files and either exits with an unexpected error or never finishes.
    ... for 6 Channel wave File .wav or monofiles .wavs
    I am trying to get 7 individual wav files, not 6.
  4. perhaps there is an error with your file? eac3to can definitely handle dts-es
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Has it been encoded with discrete channels and not matrixed ? DTS-ES doesn't automatically imply 6.1 discrete channels
    Read my blog here.
    Mar 2006
    Australia
    I'm not 100% sure, but according to this, the files that I've tried are DTS-ES - discrete
    (The Running Man & Lord of the Rings; all R4, original DVDs)
    Is there a way to tell?
    I've extracted the DTS tracks using MeGUI's DVG creator and would normally re-encode to AC3 640 kbps, but eAC3to does not like my DTS-ES tracks.
    I've got access to Sony Vegas 9 and I've used it to fix the Star Wars R4 DVDs that had the Dolby Digital EX flag turned off. If I can convert the DTS-ES to DD-EX, I'll be happy.
    I'll upload a screen-grab of the error it gives me when I get home from work.
  7. You can use mediainfo, it will tell you the variety of DTS you have
    In order to use eac3to to decode 6.1 , only sonic or arcsoft decoders will function properly to output 7 channel from DTS-ES 6.1; the free libav will only support 5.1 (so you have to downmix to 6 channel)
    Mar 2006
    Australia
    MediaInfo reports trhe DTS-ES file as:
    General
    Complete name                    : V:\Movies\Have DTS\The Running Man (dts-es)_Track2.dts
    Format                           : DTS
    Format/Info                      : Digital Theater Systems
    File size                        : 544 MiB
    Duration                         : 1h 40mn
    Overall bit rate                 : 755 Kbps
    Audio
    Format                           : DTS
    Format profile                   : ES
    Duration                         : 1h 40mn
    Bit rate mode                    : Constant
    Bit rate                         : 755 Kbps
    Channel(s)                       : 7 channels
    Channel positions                : Front: L C R, Rear: L C R, LFE
    Sampling rate                    : 48.0 KHz
    Resolution                       : 24 bits
    Stream size                      : 544 MiB (100%)
    Trying to convert to AC3, eAC3to outputs:
    and never finishes.
  9. I thought you wanted 7 mono wavs, not AC3. You would use "wavs" in the commandline
    add the -down6 switch if you want to downmix to 5.1 (6channel) AC3
    edit: actually the sonic decoder version you're using only decodes at 5.1 if you read the log , you might have to use arcsoft or a different sonic decoder version to get 6.1 (7 channel)
  10. Originally Posted by poisondeathray View Post
    I hang on this with one question.
    I have a 6ch (5.1) ac3 is ther a way to get this to 8ch (7.1) I have a 7.1 audio system and would really have sound in those last two speakers..
    Or maybe that is not how it is supposed to be ?
  11. I have a 6ch (5.1) ac3 is ther a way to get this to 8ch (7.1) I have a 7.1 audio system and would really have sound in those last two speakers..
    you can try to upmix it to 7.1 (search google there should be some threads on it), or use Dolby Pro Logic (I think IIx or something, not sure) , eitherway it's not going to be as good as a mastered 7.1 track
    Mar 2006
    Australia
    Well, I actually want to convert the DTS-ES to DD-EX, but if I can extract the 7 discrete channels as WAV, I can use vegas 9 to combine into DD-EX.
  13. well you need a proper decoder , in order to "hear" all 7 channels (6.1) or decode 7 mono wavs, otherwise you can only downmix to 6 channels (5.1). Even when you use the free libav or other decoders, I think that channel information is discarded, not properly downmixed, unless you use a proper decoder that can "see" all 7 channels
  14. Originally Posted by poisondeathray View Post
    Ok thanks..
    I will google it.
    Mar 2006
    Australia
    I just tried with arcsoft and it produced 7 individual WAV files, but there was something wrong with them. Too much high-frequency and noise.
    Same occurs when I try to create an AC3 file.
    At least now it's kinda working...
    Sep 2010
    Oman
    how do u break down a dts or ac3 into its component channels, with each channel in its own individual file.
    Mar 2006
    Australia
    Use eAC3to and select the target type as "wavs". This will save each audio track as an individual .WAV file
    Friendly beatings available, inquire within.
