Hi I'm trying to convert an AAC LC 5.1ch audio file to AAC LC 2ch stereo. I want to be able to play this movie on my Sony Walkman so the audio needs to be in a 2 channel format.
I've tried using MeGUI with neroAacEnc but the program crashes immediately (Windows error message "MeGUI.exe has encountered a problem and needs to close). Next i tried using Super....same result, program crashed immediately (Windows error message "Super.exe has encountered a problem and needs to close).
Next i did some digging. I found this post by MajTJK0ng and decided to follow his instructions:
http://www.avforums.com/forums/xbox-360-multimedia-streaming/725306-how-do-i-convert-m...el-stereo.html
So i found a copy of MediaCoder Audio Edition 0.7.2.4594, i have winamp so i was able to copy enc_aacplus.dll and nscrt.dll and pasted them into the codec folder of MediaCoder Audio Edition under program files. I set the settings EXACTLY as MajTJK0ng had them in his post and the program crashed immediately just as it had with MEGUI and Super (Windows error message "faac.exe has encountered a problem and needs to close).
I've used MeGUI to encode DTS 5.1ch and AC3 5.1ch to AAC LC 5.1ch many times without any problems. Does anybody have any ideas as to what i need to do?
I would suggest doing it in two steps:
1. decode to wav with NeroAACDec (you may need to put it in an mp4 container first) or FAAD
"neroaacdec -if input.mp4 -of ouput.wav"
"faad -o output.wav input.aac"
2. encode to 2ch AAC with eac3to: "eac3to output.wav output.aac -down2"
If you have Nero 7 (8 won't work) or one of the other paid-for AAC decoders, then you can skip the first part and just use eac3to.
Doing it in steps like this will let you see any error messages that might occur and proceed accordingly.
Slainte
middersVolunteer for https://www.computersforkids.org.uk/ -
In megui, did you remember to set the program paths in the configuration for neroaacenc.exe?
Is it possible your audio source is corrupted? -
This is the info that Super displays when the audio file is double clicked
Format : ADTS Format/Info : Audio Data Transport Stream File size : 150 MiB
Audio Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : Yes Format settings, PS : No Muxing mode : ADTS Bit rate mode : Variable Channel(s) : 6 channels Sampling rate : 48.0 KHz Stream size : 150 MiB (100%)
I'm not sure how to get the log file. -
@ poisondeathray
I'm not sure if you remember my problem with MeGUI regarding x264 not functioning properly. The problem turned out to be that the latest version of x264 was not compatible with my pc AMD Athlon 2800+ 32 bit processor. The fix was that you gave me a link to an older build that was compatible with my pc.
I am wondering if this is the same case with eac3to as that program was also updated? Perhaps i need to use an older build?
MeGUI is not providing me with any logs due to the fact that the program just crashes once i try to encode. what is funny is that MeGUI WILL encode an AC3 to AAC no problem. Also it WILL encode DTS to AAC no problem.
I also tried downmixing to Dolby Pro Logic II and forcing Direct Show Decode...to no avail.
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 08:41 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 16:58 -
AAC 5.1CH audio plays as 2CH on my DSM-750 media player
By roise_r in forum AudioReplies: 0Last Post: 22nd Aug 2009, 22:45 -
Problem using GraphEdit for AAC audio conversion
By Alterego in forum AudioReplies: 0Last Post: 21st Dec 2008, 12:41 -
MKV to MP4 for PS3 with dual-audio (2ch AAC + 6ch AC3)
By sexyclient in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Dec 2008, 22:01
