I've been trying to convert some MKV format episodes of Top Gear to DVD format so I can play it on a regular DVD player. I'm having issues because when the project is complete it's not recognized on a regular DVD player. I'm using DVD +R discs, is that the problem?
I put the burned DVD into a playstation 2 and it does play but it's very jerky. Could it be that the DVD file is too big, or that it's HD quality so it won't play in something so old?
If you created a proper DVD-Video disc, it can't be HD video - DVD-Video's maximum is 720x576 (PAL) or 720x480 (NTSC), and your converter would have changed it to those resolutions or lower. Chances are, it's probably something to do with the media you used, though I think it's possible you could've used too high a bitrate (someone will have to correct me on that one), but rather unlikely.
Edit: Also see manono's reply to your other (similar) topic, here.If cameras add ten pounds, why would people want to eat them? -
Yes mine was created at 720X480. I'm actually converting from an MKV file. What is a good bitrate to consider?
Problems after converting mkv to blu-ray format
By BigGreenie in forum Video ConversionReplies: 17Last Post: 7th Jan 2012, 06:27 -
converting audio format in .MKV
By Sliver in forum Video ConversionReplies: 3Last Post: 24th Jul 2011, 07:09 -
Problems converting recent mkv's to ps3 format!??
By josetjr in forum Video ConversionReplies: 1Last Post: 25th Sep 2010, 06:15 -
Converting MKV file to DVD burnable format
By ryoden in forum Video ConversionReplies: 6Last Post: 29th Jul 2008, 13:54 -
In need of help with converting .mkv to .avi format
By nabeelnk1 in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2007, 15:47
