I am thinking that I would like to connect my cable box up to a projector. It seems like a neat idea to project the TV signal onto the wall in my place. Anyone ever try this?
I have looked up projectors online and it seems like they cost 300 bucks and up. Is there a cheaper way to do this? I am not super picky about quality at this point.
Thanks,
TC
If your cable box outputs a proper signal for the projector, should work. SD TV video may not look so good, though.
You won't find many decent projectors below $600US, more commonly around $1000, depending on the specifications and performance. You also need a screen to get good quality and contrast. And projectors need low light or darkened rooms, so not so useful in the daytime.
You also need to consider projection bulb replacement costs. They can be very expensive.
Connect LCD monitor to Digital HD Cable box?
By rogerconnery in forum DVB / IPTVReplies: 84Last Post: 18th Jan 2012, 07:04 -
How would I connect my standard cable box to my HD LCD monitor?
By Jadedrain_06 in forum Video ConversionReplies: 4Last Post: 27th Nov 2011, 13:00 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
How to connect a monitor to a digitanl cable box?
By Latvian in forum DVB / IPTVReplies: 3Last Post: 3rd Dec 2008, 01:47 -
How to connect my cable box to my computer~~? THX~~
By bl3311 in forum DVB / IPTVReplies: 2Last Post: 25th Mar 2008, 19:47
