I've used Ac3Gain and continue to on my XP 64-bit system, but I just built a new pc (Phenom 9550 /w Windows 7 Home Premium 64) and it doesn't want to run (builds the avs file & just stops). I see aften *32 process running, but no cpu usage and only 432k memory. The file I'm working with is processing fine on my other pc. Any Known Issues?
Results 1 to 13 of 13
did you try setting it to run as admin?
Yep! Wavi too. Tried compatibility modes, still no luck... so far...
Weird, you should be feeding it AC3 files
"Quality is cool, but don't forget... Content is King!" -
I'm not a lot of help on this one. Works perfectly on XP 32.
DVD Shrink won't recognize Nero(New PC with Windows 7 64 bit)
By Jonathan in forum DVD RippingReplies: 19Last Post: 1st Jun 2011, 09:41 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
XP Pro 32-bit v. Windows 7 64 bit
By edong in forum ComputerReplies: 13Last Post: 12th Aug 2010, 13:28 -
What are the advantages of 64-bit over the 32-bit version of Windows?
By edong in forum ComputerReplies: 20Last Post: 30th Oct 2009, 12:20 -
32-bit program Micrografx on 64-bit windows vista?
By Obamargarine in forum ComputerReplies: 8Last Post: 11th Aug 2009, 19:56
