I am trying to convert an MKV file to dvd but I am having a particular problem with one such file. First since TMPGEnc Authoring Works cannot import this file directly, I use mkvtovob to convert the file to an mpeg. Then I put in into Authoring works but it reads the file as being twice as long. The video is about 3 hours but TMPGEnc reads it as 6. Because of this, I cannot author the dvd. What causes this discrepancy?
mkv2vob should only be used if you are going to play it on a ps3. It does not create a standard vob.
Use instead avstodvd to convert directly to dvd or a mpg that you can import in tmpgenc authoring works.
VOB Wrong Length When Imported
By DebiKay in forum DVD RippingReplies: 3Last Post: 29th Apr 2012, 21:39 -
vob file has wrong length?
By Brainbanana in forum Video ConversionReplies: 16Last Post: 1st Mar 2012, 14:52 -
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
Vob File Length seems all wrong
By AlexHaden in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2008, 19:34 -
AVICodec reports wrong frames per sec
By igorek in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2007, 19:27
