Say you're re-encoding a 16/9 DVD to Xvid at a typical ( 1000-1500 kbps) bitrate. What resolution do you use? 640x360? 720x404? Something else?
What criteria do you use to make your choice? Would you apply the same rationale to a 4/3 rip? Or other A/Rs?
I don't suppose there's a right or wrong answer, I was just interested in what experienced rippers thought.![]()
I leave the resolution the same as the DVD and set the Xvid PAR/DAR flags. You'll have to make sure your player supports this though.
resolution avi's
By surfer in forum Video ConversionReplies: 25Last Post: 13th Sep 2009, 12:14 -
AVI conversion to 16:9 resolution
By kyrcy in forum Video ConversionReplies: 3Last Post: 2nd Jun 2009, 12:23 -
screen resolution avi to dvd?
By drwho in forum Video ConversionReplies: 3Last Post: 14th May 2008, 19:25 -
Player .avi resolution
By Trailryder in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Dec 2007, 13:17 -
AVI Output Resolution?
By rowlers in forum DVD RippingReplies: 13Last Post: 31st Oct 2007, 13:14
