Hi There
I have a sony tv and sony dvd player/recorder which I play audio cd's and shop bought dvd fims.
I have Toshibs laptop using xp home.
I have Toshiba "record now"
I have Nero 6
I have downloaded/installed/removed several dvd convert/burn/rip progs as they are either complicated or only trial progs and I don't want to pay.
What I want to do/know/is...if I have a dvd saved to my hard drive, or if I have a dvd given to me that has been downloaded, I can play on my laptop without any trouble, but if I want to play a downloaded dvd on my Sony dvd player, it often wont play as format is no good.
What is the best format a dvd needs to have to play on my Sony, and what is the best way/prog to use to allow me to do so.
I changed your thread title. Don't just use newbie question. You can edit it by clicking on the edit button on your first post.
Back to the topic,
Use good dvd media, www.nomorecoasters.com , and use also good dvd-video converters like the free dvd flick or if your sony supports avi divx/xvid then convert to that using autogk. -
I have a problem just like yours... check out... https://forum.videohelp.com/threads/334069-HELP-Sony-HT-Cant-play-athoured-dvd?p=2072644&posted=1
I don't have the solution yet... but... maybe you can try something....
Sony RDR-HXD890. DVD+/- RWs : Format Failed.
By Mr Mooney in forum DVD & Blu-ray RecordersReplies: 14Last Post: 27th Sep 2017, 17:53 -
Burn from to DVD but what format to play on tv?
By Claxlast in forum Authoring (DVD)Replies: 5Last Post: 18th Mar 2011, 17:57 -
My Sony CD/DVD player (NS55P) would almost only play sony discs.
By valdes001 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jan 2011, 11:03 -
Which format is best to capture and edit from DVD's in Sony Vegas
By fuzzblaster in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2010, 08:38 -
From video camcorder to DVD format using Sony Recorder
By Noek in forum Newbie / General discussionsReplies: 7Last Post: 24th Nov 2008, 22:00
