Hello
I am new to Blu - ray burning.
My equipment -
i7
6 gig ram
1 terabyte hard drive with 75% space
LG Super Multi Blue burner
9800 GT EVA video card with one gig ram
Slysoft Any DVD, Slysoft Clone DVD2
Nero 9
On my first time to copy a new Disney Blu-ray I tied my Slysoft Clone DVD2 software and it would not recognize the disk.
Next, I tried on my NERO 8 software. I clicked on "Copy Disk". It copied the original disk onto my hard drive........... then it asked me for a blank disk to copy to. I put in a new Sony 25 gig BD-R and I received this message "There is not enough space to burn the compilation to this disk."
How do I copy a factory Bu-Ray disk? What am I doing wrong?
tryin' bryan
Results 1 to 12 of 12
Sounds like you're "far too lazy" to look through this site that has a wealth of knowledge and a plethora of tools. Did you look at any of the guides that were on the download page for BDRB? Also, did you use the pane on the left side of your labeled "How To". Here's one of them:
https://forum.videohelp.com/threads/299579-How-to-shrink-a-Blu-ray-to-DVD-5-DVD-9-or-BD-25 -
BDRB: Requires ffdshow, Haali Media Splitter and avisynth. I consider those tools pretty much essential to working with any BD/HD material. And I don't even use BDRB. You can also use tsMuxeR and just select the main movie and the AC3 6ch track and the video may fit on a BD RW without any 'shrinking'. I can usually drop 5GB off the file with just that. It only takes a few minutes. If you re-encode the file(s), it will take several hours.
Yes, you could but I doubt it will play in any standalone player. You would have to make a custom menu to navigate to each title in order for it to be playable on a blu ray player.
Thank you very much.
I am looking for a simple way to way to copy a Blu-Ray DVD disk (titles and all).
QUESTION: Does this AVS Disk Copy have a "Fit to Disk " feature? What I mean is that ..........will this AVS DVD Copy software automatically set itself for the best video and audio settings and compress the DVD files to fit a blank 25 gig BD-R Blu-Ray disc if the size is too large?
Thank you,
tryin' bryan
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 19:25 -
blu-ray burning
By ttheb1 in forum Authoring (Blu-ray)Replies: 2Last Post: 14th Jun 2010, 04:58 -
Burning Blu Ray from ripped Blu Ray
By ppurdue in forum Blu-ray RippingReplies: 10Last Post: 15th Oct 2008, 20:51 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
