Hello,
I've shooted some video's with an Sony D8 camcorder and Nokia N95.
Now I've edited it in Vegas, but the problem is Sony's footage is interlaced and Nokia's Progressive.
Wich is the best way to encode? Interlaced or Progressive? I will do 15MBs MPEG2.
It would be logical to keep the interlaced interlaced and progressive progressive, but that isn't possible.
And this time more then half the footage is shooted with the N95
The flag once raised will never fall!
it depends what the goal and target is (how are you going to view this)?
The most important thing is I want to minimize motion loss and archive. The video is 4:3 and I want to watch trough TV Out (crt screen for now)
Playing interlaced on computer isn't a problem since VLC can deinterlace. So it isn't really a problem for me how to view it.The flag once raised will never fall! -
The only way to minimize motion loss (if you mean keep it smooth, and the temporal resolution) is either to keep the interlacing (and bob-deinterlace on playback) , or bob-deinterlace to progressive
However, if you progressive footage was shot at a lower fps, it won't intermix very nicely.
e.g. if you had 30i (or 60 fields per second) footage, you would need 60p footage to mix nicely. If you only had 30p progressive footage, it is at 1/2 the temporal sampling -
If you want to preserve the motion , interlace is better
25fps interlaced is 25 frames per second or 50 fields per second. When you bob deinterlace it's silky smooth because you get the full 50 samples of time. When you single rate deinterlace, its 25 sample per second. You can test this for yourself. Play in VLC normal deinterlace vs. bob deinterlace, the difference should be clear
The problem is your nokia doesn't have the same temporal resolutions. The footage only takes 30 moments in time, not 50. Do you see the problem? In order to intermix them, vegas will either blend frames (blurry and choppy) or duplicate frames (very choppy)- you can test this out for yourself. When you use default behaviour, it will blend, when you "disable resample" it will duplicate -
I thought I've tested it, but I didn't see a difference. Probably one of the footage wasn't interlaced..
I will export again and look. But I do have used earlier 30fps to 25fps. The most footage of Nokia is 27fps, so that wasn't really a problem (but now Im doing interlacing, another story). But I will check again.The flag once raised will never fall! -
I didn't really see a difference. The Nokia often shoots 26 or 27fps average, so it's almost 25 fps.
If I do 30 fps it becomes really annoying sometimes (on Nokia footage).
So I choose 25fps interlaced. I think that's a great average.
On the Nokia, I hate it that it has a variable framerate, I always have to guess/decide wich framerate will be used for the next project, I hate it! I don't know why they can't just choose 25fps or 30fps....
But Thanks for your help and suggestions poisondeathray
NTSC : progressive or interlaced
By mathmax in forum Authoring (DVD)Replies: 54Last Post: 2nd Feb 2012, 08:06 -
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 10:22 -
Interlaced or progressive
By rank in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2010, 17:41 -
Does de-interlaced video = progressive?
By yoda313 in forum RestorationReplies: 13Last Post: 18th Aug 2008, 20:51 -
progressive footage encoded as interlaced mpeg2
By misapito in forum Newbie / General discussionsReplies: 9Last Post: 4th Mar 2008, 09:44
