I need a program (free or NON-free) that has the video conversion features of Quicktime Pro. Namely, it should be able to convert the audio+video codecs in a MOV/AVI/MPG/DIVX, etc. file to the various formats that QT Pro supports. I'm using Windows XP. Some help would be great.
Thanks in advance.
Results 1 to 10 of 10
MpegStreamClip comes close, although you'll need to buy the Quicktime Mpeg2 plugin from Apple to convert mpeg2 files. Don't know about Divx/Xvid support, however.
"Quality is cool, but don't forget... Content is King!" -
yes ffmpeg supports conversions to and from .mov . The problem is to get the most functionality, you have to use command line (most gui's wont have presets for quicktime stuff). Gui's make use easier by simplifying the process and creating the commandlines in the background for you.
the .mov container is the single thing that defines quicktime. It is a container (think of it like a box) that holds different types of video & audio. There are dozens of different kinds so "mov" is very non specific and doesn't provide much information at all.
mpegstreamclip uses the quicktime api - so all plugins you have for quicktime pro are functional in mpegstreamclip -
Does Quicktime Pro come with MPEG-2 plugin? Do i need to have Quicktime installed for Mpegstreamclip to work? Hmm...I prefer NOT to deal with a commandline, so i might stick with Quicktime Pro, then. I've tamed the beast that's QT Pro, namely qttask.exe. It still wants to play ALL media on the web, though....
no the MPEG2 plugin is a separate addon ($)
mpegstreamclip will work with quicktime alternative (free) or QTpro . However, there is a special version of quicktime alternative that is required (the instructions and links are on the author's website)
haha. I just kill it with my software firewall and don't give permissions to start or work. You can also disable it for windows startup
Can I ask why the need for this QT compatibility? especially on a PC platform? -
In regard to what Quicktime will attempt to play:
You probably already know to check the File Types tab in Quicktime's Control Panel and make sure everything you don't want QT to handle is unchecked. But you also need to do the same in the Browser tab > click the "MIME Settings..." button. That should help with QT trying to play everything in your web browsers.If cameras add ten pounds, why would people want to eat them? -
I do music on film scores, and I usually get .MOV file(s) of the movie.Can I ask why the need for this QT compatibility? especially on a PC platform?
Oh, i did set the 'MIME' settings of Quicktime, but the beast rears it ugly Q mark, nonetheless....
Any video converter seems barebones to me, may try the Pro version, though. I also found Total Video Converter, anybody use that before? -
Which browser are you using? Some of them, like Firefox, also maintain a list of applications/actions to take when certain types of files are encountered.
Quicktime Pro 7
By JBird in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 11:15 -
Best .mts to Quicktime .mov converter?
By nojiri in forum Video ConversionReplies: 3Last Post: 28th Jun 2010, 19:54 -
.mov to .flv converter (upgrade to quicktime pro the answer)?
By claydoctor in forum MacReplies: 1Last Post: 29th May 2009, 07:24 -
Frameserve to Quicktime Pro?
By Lippy Lipstick in forum Video ConversionReplies: 16Last Post: 3rd Apr 2009, 03:02 -
QuickTime Codec for WinAVI MP4 Converter
By neumannu47 in forum Video ConversionReplies: 4Last Post: 6th Sep 2008, 10:41
