Hi,
I am using AC3gain to change the Bitrate of an AC3 (5.1 Channel) file from 448 kbps to 192 kbps using AC3gain.
Total file duration of the original files is 2Hours & 47 Minutes. But after encoding the duration of final Output file is 43 Minutes only....
Pls. Help.........
If it's a bad movie, that might be a good thing!
Try https://www.videohelp.com/tools/TFM_Audio_Tool or eac3to instead
You can also try to update the Aften.exe inside the AC3Gain package"Quality is cool, but don't forget... Content is King!" -
Changing the bitrate should not have that effect. I think somehow you resampled.
Hi,
Thanks for your quick replies......
I have download AC3gain from another link http://www.users.on.net/~pcspeak/files/ac3gain.zip and now the problem is resolved....
Thanks........Last edited by dabas; 31st Jan 2010 at 13:16. Reason: Hyperlink correction
Changing bitrate of an audio file
By prohank in forum AudioReplies: 2Last Post: 6th Mar 2011, 07:34 -
changing audio bitrate with ffmpeg
By wallywalters in forum Video ConversionReplies: 4Last Post: 11th Feb 2011, 05:45 -
Changing AVI Bitrate!
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2008, 12:23 -
Changing AC-3 Bitrate
By kotton in forum AudioReplies: 5Last Post: 1st Sep 2007, 23:29 -
By kotton in forum Video ConversionReplies: 2Last Post: 1st Sep 2007, 22:05
