  1. Hi,
    I have about 60 videos that I need to convert to digital for onward DVD authoring. I have started into this and completed about 5 tapes so far, however it is extremely time consuming . I am using a Canopus ADVC 300 with a well spec'ed Dell XPS. During capture the machine is hardly breaking a sweat which leads me to believe it must be possible to run a number of captures simultaneously.
    Is this something that any of you have experience with? What is the best hardware / software for the job?
    Many thanks in advance.
    Porto
    PS - if you need any further info please let me know.
    May 2007
    Romania
    I have done two simultaneous recording from two VHS tapes with two tuners and save each (uncompressed) on different HDD. With 5 players, five tv tuners (or 5 Canopus boxes) and multiple disks may be possible.
  3. Thanks Danno.
    What software would I use?
    The default Microsoft Movie Maker s/w will only allow one session at a time.
  4. Our software (see signature) can capture from multiple DV sources. I've used it to capture 15 x 1 hour tapes in less than 4 hours by using 4 camcorders simultaneously with the same PC.
    John Miller
    May 2007
    Romania
    In my case (tuners) it was two filters of graphedit. For DV sources you should follow Johnny advice.
    One graph filter:
Name:	uncompressed output.png
  6. Thanks guys.
    John - I will give your software a try!
  7. I heard of people capturing six videos simultaneously with the Hauppauge PVR-250. Or maybe it was the PVR-500 (the dual tuner version). It's easy to do with all the hardware MPEG2 encoders because all you have to do is save the MPEG stream to a file. I believe you can also record multiple videos using several Hauppauge HD PVR USB devices (hardware h.264 encoder).
