I want to convert MKV to AVI. And the mkv contain softsub. How can i do that? I have used avidemux but for me it shows always crash problem. and i have also used any video converter works perfect. But the problem is any video converter do not use the font that subtitle(.acc) file contain. any help please.
I also want to put water mark text in particular time line like 2:00min- 2:15min. any good easy software (commercial or freeware) that can do it easily?
Post Updated!
What version? you could try latest beta build from http://avidemux.razorbyte.com.au/
But avidemux may be very buggy with some mkvs. You could try xvid4psp or staxrip instead, load mkv, choose avi xvid profile, load the subtitle and convert.
And some other free tools you can try are format factory, any video converter free. They should also be able to burn in subs. -
I have used 2.5.2 (5660) this one. okies i will try those appz that you suggested many many thanks.
avidmux is good as after convert everything in default option video looks perfect. Is there anyway to fix that crash problem
You could try AviDemux 2.4.4. I've kind of stuck with that version because it's the last one that does good one pass .avi encoding. With 2.5 they changed the xvid settings for one pass to reduce the motion detection or something. Comes out looking like a semi-transparent checkerboard was placed over the video. But Baldrick is right. It's not the most stable for encoding .mkv.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
2.4.4. for me too. Never had a problem.....but I don't do MKV either.
Under x264 settings make sure the Motion Estimation method is set to Hexagonal Search. I've gotten crashes if I try another setting
"Quality is cool, but don't forget... Content is King!"
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
Problem with Avidemux 2.5
By MohamedYousri in forum Newbie / General discussionsReplies: 13Last Post: 3rd Jan 2011, 16:37 -
Avidemux Problem.
By tremor209 in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2010, 04:39 -
Avidemux Problem...
By userpc in forum EditingReplies: 0Last Post: 6th Oct 2010, 08:52 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38
